2.9 Pulley change
Old 04-05-2008, 03:56 PM
blownredSS's Avatar
2.9 Pulley change
For those of you who changed their pulley I say congratulations! How the hell did you take the bolts off and keep the pulley from turning. The tensioner pulley is plastic, can't put much pressure on it with the pry bar up against the supercharger pulley with out wrecking it. Any suggestions!!!!! Beside taking the SC off.
Old 04-05-2008, 04:23 PM
Infernokron's Avatar
If you leave the belt on then the pulley shouldn't spin when you try to un-screw the bolts. The stage 2 bolts can be a real bitch sometimes though, some people have heat them up, use vice grips to get them off, drill them out etc.
Old 04-05-2008, 04:27 PM
blownredSS's Avatar
It turns, the belt and everything!
Old 04-05-2008, 04:28 PM
Stouffer's Avatar
Strap Wrench and an extra set of hands if you don't want to remove the s/c
Old 04-05-2008, 04:42 PM
SloboltSS's Avatar
use a small screwdriver and wedge it between the bolts that are still on the pully. use it like a lever to keep it from turning. loosen all the bolts before removing any of them. if you position the screwdriver right the pully will stay still.
Old 04-05-2008, 04:48 PM
BriantheLion26's Avatar
Put the car in 1st gear and start wrenching on the bolts. After a turn or so it will tighten up. Break um all loose and take it out of gear. Do the same to tighten them up.
Old 04-05-2008, 05:55 PM
Littlegoose's Avatar
Just yesterday I swapped the S2 bolts with Nate's bolts and I took a crow bar (yeah I know, excessive haha didn't have a prybar) and put it between the tensioner pulley and the SC pulley and then pulled towards me. I was able to do it by myself by putting the crowbar under my armpit and leaning a little towards the front of the car (not much pressure just enough to hold the sc pulley still) so it was pushing the tensioner pulley upward and towards the rear of the car and the sc downward and towards the front of the car (in terms of force, not actually pushing them lol). Worked well enough to get all bolts cracked no problem. After they were cracked, didn't need the crowbar.
PM me and I'll send you the steps USMCFieldMP sent me, they were great and had pictures.
Old 04-06-2008, 02:18 AM
rukkee's Avatar
Strap wrench is the best way , saves alot of abuse on the pulley .
Old 04-06-2008, 03:11 PM
blownredSS's Avatar
Jesus!!! I bought a strap wrench, works great only I snapped the pulley bolt bit in 2. What the christ? Looks like there's no 2.9 in the future for me!!!
Old 04-06-2008, 05:25 PM
holy hell thats nuts.
Old 04-06-2008, 05:47 PM
07 SS/SC's Avatar
Damn good thing I helped the mechanic install my S2 kit and slapped him when he picked up the lock-tite. My bolts are a breeze to take off.
Old 04-06-2008, 06:06 PM
blownredSS's Avatar
Loc-tite! I think mine are friggin welded on.
Old 04-06-2008, 07:52 PM
Stouffer's Avatar
What I ended up doing was removing the supercharger and putting a little bit of heat on the bolts to help free them up.
Old 04-06-2008, 08:08 PM
blownredSS's Avatar
Yea, thats what I'm gonna end up doing, I figure I'll put a dual pass on at the same time.
Old 04-08-2008, 09:11 AM
Texas SS's Avatar
I want a 2.9 but dunno yet
Old 04-08-2008, 04:35 PM
chad463's Avatar
I am having the same problem with these bolts. I cant seem to get them off.
Old 04-08-2008, 04:40 PM
rizoforever's Avatar
they used tons of lock-tite on my bolts and after trying everything to get them out i ended up pulling the supercharger out and drilling the bolts. it didnt take long and it was easy to do!
wisemanonice's Avatar
I have had my 2.9 sence way b4 thanksgiving. I couldnt get it off. the shop I took it to couldnt get it off. So now Im just gunna swap the whole blower
Old 04-08-2008, 04:45 PM
chad463's Avatar
so you had to take the blower off? Anyone have a write up on how they got these bolts off?
07cobaltss's Avatar
remember, right tightie, leftie loseie
Old 04-08-2008, 04:51 PM
chad463's Avatar
lol, these things are stuck on and it keeps moving.
Old 04-08-2008, 07:46 PM
i would just go through the trouble of taking the blower off, its not that hard and once you are done it will be worth it!
Old 04-08-2008, 08:03 PM
PM'ed with how-to
Old 04-08-2008, 08:31 PM
chad463's Avatar
thanks for the pm, I am going to try that out tomorrow.
Old 04-08-2008, 08:58 PM
blownredSS's Avatar
Littlegoose, wanna Pm me with that how to, too!!
Quick Reply: 2.9 Pulley change
