300+ horse on the m62...
Old 09-01-2011, 10:02 AM
ccbalt22's Avatar
looking for input on guys who are over 300 on the m62... how you got there what you all got done cheapest way and what product gave you the biggest gain...also how safe is your set up...
Old 09-01-2011, 10:06 AM
Sylver01's Avatar
I'm not anywhere near 300 hp but don't think you will find very many people if any at all that have hit 300 with a M62
Old 09-01-2011, 10:12 AM
BYT*SS*TURBO's Avatar
E85, ported head and cams would be nice.
Old 09-01-2011, 10:29 AM
jonathan923's Avatar
theres only one or two people that have reach that power on an m62 that i know of. one thing is for sure, it wont be cheap. and it will take just about every single possible thing to get there. from e85 and ported head as stated above to every bolt on, cooling mods and some serious tunning
Old 09-01-2011, 10:31 AM
Administrator
Administrator
Staged07SS's Avatar
You havent been around long enough....
Infact, there is an active member on here who is 300+whp right now with the M62.
A handful of people reached that number back in the day. It's a little easier to achieve now with E85 though.
Old 09-01-2011, 10:32 AM
ya u'd prbly need a very aggresive tune, probly e85 which means 80's, prbly a 2.6" pulley, then all the cooling mods to support that heat, while ur at it meth kit... spacers between the thrttle body, the supercharger... not going internals yet
Old 09-01-2011, 10:34 AM
Administrator
Administrator
Staged07SS's Avatar
People did it w/o E85 a long, long time ago.
It can be done, and as I said in my previous post, E85 makes it easier.
Old 09-01-2011, 10:48 AM
ccbalt22's Avatar
lol ok well let me ask then what is the most power i can make on the m62 blower safely...
Old 09-01-2011, 10:51 AM
Administrator
Administrator
Staged07SS's Avatar
There are too many factors to say what is safe & what is not safe.
In general:
Safe = a spot on tune & the proper supporting mods to handle the increased power (along with having a healthy car to begin with).
The limit of safe power depends highly on the setup.
Old 09-01-2011, 10:52 AM
35-50 shot lol
myfakeevo's Avatar
i bought all my parts off of a friend before he sold his car he had 317whp. while i run a detuned version of his set up his was:zzp shorty, catless 3inch downpipe, gmpp exhaust, 2.6 pulley, meth, ALL cooling mods, 3 inch intake, valve springs, aggressive tune
easiest way, e85, ported head, 2.7 pulley, exhaust mods.
Old 09-01-2011, 11:05 AM
Administrator
Administrator
Staged07SS's Avatar
Who was your friend??
That sounds like either 06Blacks old setup or Ecojoey's (Slowlsj's Redline Forums) old setup.
Old 09-01-2011, 11:16 AM
Dart_SI's Avatar
2.4L stroker kit.
Old 09-01-2011, 11:17 AM
blake05SS's Avatar
sub'd this thread has some potential for useful info
Old 09-01-2011, 11:22 AM
ccbalt22's Avatar
from what i have heard a way to get closeis
-2.7
-80's
-e-85
cooling mods
stage one cams
exhaust.
Old 09-01-2011, 11:27 AM
freakta's Avatar
zzp did well over that on an m62 with e85 and lots of rpms
but cheapest way... 2.6 pulley, cooling, full 3in exhaust, valve springs, exhaust side ported head, meth or e85, lots of rpms and a happy dyno
Old 09-01-2011, 11:28 AM
blake05SS's Avatar
i havnt heard much about the cams what cams u guys talking about where is ebristol with his dyno sheets
Old 09-01-2011, 11:31 AM
ccbalt22's Avatar
zzp makes the cams. those are the only ones iv done research on. stage one is just a replacement preety much. allows you to run higher rpms....but stage 2 is a big upgrade... lifters retainers 78/lbs springs and cams...with head studs, preety much building top end.
Old 09-01-2011, 11:34 AM
ccbalt22's Avatar
now im preety new at this iv had 3 ss's but never really got deep in them... y woudl you only port exhaust side? and iv heard meth is better and also e-85 is better...opinion on one or the other? also if im gonna run higher rpms do you guys suggest the top end build?? or just...
Old 09-01-2011, 11:35 AM
myfakeevo's Avatar
i dont know his user name on here, but its about jimmyc607 from 607 motorsports
Old 09-01-2011, 11:36 AM
blake05SS's Avatar
only port exhaust side because u have fi there is no need to port the intake side altho some still do its ur choice really
Old 09-01-2011, 11:40 AM
Administrator
Administrator
Staged07SS's Avatar
If you saw the exhaust ports on an LSJ head you would understand why.
Old 09-01-2011, 11:42 AM
ccbalt22's Avatar
and for cooling mods
front mount heat exchange
dual pass end plate
option b
any more?
Old 09-01-2011, 11:45 AM
ccbalt22's Avatar
from what ive read there preeety restrictive...where could i go about getting that done?
Old 09-01-2011, 12:24 PM
Leafydialupking's Avatar
Well right to 300 is not that hard, just no one does it. Normal bolt ons, 2.8 or smaller pulley, ported head and custom cams (and supporting valves, springs, blah blah) with either meth or e85. Now to make 400 theres two choices.
The torque monster choice which will rev to 7 grand and make the power.
All of the above with an LE5 bottom end and LSJ head ported on e85. Also adjustable cam gears that will be tuned on the dyno. Note, this will require a different cam than the above setup. You will have ~11:1 compression which will make e85 required but the blower will love it.
The high rev machine
LE5 block with LSJ crank, LSJ rods, and large bore LSJ pistons with a slight dish to bring the compression down to about 10:1. This give you about a 2.1L engine. Cams (and cam gears), springs, balance shaft delete and rev it to 9 grand (you really should use a stand alone at this point). E85 again, maybe meth too. This one is more certain to make 400 hp than the LE5 bottom end setup, but its going to be peakier and higher in the rev range. This would make a better drag engine while the other setup would make and amazing auto-x/track day engine.
Reason no one's done this stuff? Its a heck of a lot more work than throwing a turbo on a stock engine and making the same peak power.
Quick Reply: 300+ horse on the m62...
