300hp Daily Driver (TVS guys chime in)
#126
I thought for a long time I could one day just upgrade to stage 3, hit 300 and call it a day on the car...but then I see numbers from the hahn kit where I could keep replacing weak links forever and crank it up....it's a dangerous road. I'm sure 300hp would be great but..can one ever say...that is enough?
#130
Rent me! per hour
#132
#135
#136
Rent me! per hour
for reference on this matter.
29psi
13.6 afr
36 degree's of timing
started pushing coolant from the reservoir. it didn't make any power at that craptastic **** up on the map.
dropped the afr. dropped the timing. didn't run it to 8300, so it was 27psi. head was fine. stock TTY bolts as well.
#137
cylinder pressure comes from a few variables. boost is one. ignition timing. cam profiles. you get the idea.
29psi
13.6 afr
29psi
13.6 afr
#138
ah ok.. from my understanding timing is pretty much stock on this tune... eh well once all that other stuff is done and i have some good log files i still gotta hire you to do some work on it.
#144
Rent me! per hour
as far as not making power. majority of the people on here will not run lean enough to use the 25+ degree's of timing anyways.
#145
ah good to know. I get knock over 15 at wot anyways so I dont think I'll test this theory lol
#146
Getaway_Driver
09-08-2015 09:41 AM
