300hp Max
Old 10-19-2005, 07:45 PM
The Stig
MarcS's Avatar
Originally Posted by UtOhCop
The LSJ's compression ratio is 9.5:1? WTF. GM is really retarded. It should be 8.5:1
8.5 would be better suited for a turbo application where higher boost numbers can be made.
Old 10-19-2005, 07:49 PM
selfinfliction's Avatar
exactly... only running 12 psi, 9.5:1 isn't that high.... running 28 psi on a 9.5:1 would be high... that's why that rebuild of 300hp someone posted they actually raised the compression up to 10.5:1 it won't make that much of a difference on a roots blower, a turbo on the other hand it would
Old 10-19-2005, 10:46 PM
beerbaron105's Avatar
high compression will give u much better low end rather then low compression pistons, the engine will be very laggy till boost kicks in to start pushing that beast!
Sl0wbaltSS
11-21-2018 11:11 PM
hhrfreek
06-04-2016 11:25 PM
TedSS
101
04-25-2016 10:46 PM
riceburner
09-30-2015 03:54 PM
Quick Reply: 300hp Max
