300whp Achieavable w/o built motor?
If this has been asked too often, please delte it**. No flaming required.
The question is, can 300whp be achieved with the stock engine/supercharger RELIABLY and safely?
Ive seen 250-260whp cars a lot but not many in the three hundred hp range. Is this considered a safe amount for this motor?
Thanks
Thanks
If you think about it. The supercharger puts about a 50hp strain on the motor. SO the motor is putting out 300 or so HP already then the supercharger sucks up about 50 then add in drive line loss ect, and you see what we are making. If you get rid of the SC you have about 50 to play with, for a turbo, granted to motor still has to push the turbo which sucks up hp but not nearly as much at the SC.
So when people are running 260 -280 reliable with he SC they can probably run 300-320 reliably with the turbo. Not to mention the air is way cooler and the ability to upgrade once you get internals to a different power level can be as easy as turning up the boost.
Thats probably why so many people such as myself are going with the turbo option
The L61 build book states you should not use the LSJ rods for anything over 350hp. If your going to replace the pistons, replace the rods too. It would be stupid not to. Rebel's turbo easily acheived 323whp on the stock engine. The procharger should easily acheive 300whp with a moderate amount of boost and much much higher at 20+psi on that C1 or C2. we will see with the twinscrew. I have no doubt it will make 300whp. Just waiting on them to iron out all the kinks.
I think it is do-able guys. Or at least pretty close.
Zinner hit 292whp/294wtq with stock internals. Here is the thread with dyno.
https://www.cobaltss.net/forums/show...e+dyno+nitrous
Thanks
Thanks
Good header
3" downpipe
3" Catback
Airbox mod
2.5" pulley
60lb injectors
Ported head
300whp
Ported head is going to free up 30+whp.
I hit 260 witha blown out flex pipe. lol
now im water injected with no knock and runnin the dual pass with a serious downpipe and a good tune.
getting dynoed at the end of this month i think.
i believe 300 whp is attainable if people do it right. really good tune, h/e, dual pass kit, water/meth kit and the main thing that i never see anybody do(not saying anybody hasnt done it yet) is port and polishing the intake manifold and heads.
ThoR294
10-04-2015 08:44 PM
