600whp tvs build round 2
Many of you know me been on here a while seems like a lifetime lol
finally getting going on the rebuild
last time around head stud had cracked the the water jacket making it **** water into the oil pan
block got stripped down and wacked with a hammer to check out the sleeve material over the weekend looks nice
NEW block is now at the machine shop getting a hone,deck and wash and the crank polished up
will be back to me in 2 weeks time
specs on the build
SHORT BLOCK:
Gen 3 2.4 LEA block low miles junk yard
stock LSJ crank with extended keyway
11:1 diamond pistons coated top and side
total seal ap rings c-33 top ring with naiper cut second ring
Pauter rods
Arp head studs
HEAD:
LSJ head CNC ported
ferrea 1mm oversized valves
new stock cast guides
supertech 75lb springs
OTTP stage 4 blower cams
ADD ONS:
TVS 1320 on a 2.3 pulley
ATI overdrive balancer
15lb nitrous express proton kit progressive 100 shot
Prometh trunk mount system dual nozzle with snow MAF controller
OTTP 3.5 cold air intake
OTTP 2in header with 3.5" downpipe
ZZP 3" cat back
QTP 3.5in cutout
ZZP stealth H.E
CTS-V fluidyne H.E
flow thru tank for dry ice
dual pass
phenolic IM spacer
probably forgetting some stuff
pictures will come soon
specs on the build
SHORT BLOCK:
Pauter rods
Arp head studs
HEAD:
LSJ head CNC ported
ADD ONS:
ZZP 3" cat back
QTP 3.5in cutout
ZZP stealth H.E
CTS-V fluidyne H.E
dual pass
phenolic IM spacer
im gonna keep an eye on this. im thinking of building an lea short block for my 944, and i have similar power goals. im interested in seeing how a stock non girdled lea block holds up to 600hp.
make sure you vent your icebox if you plan on running dry ice. plumbing the vent outside the car wouldn't be a bad idea either. I doubt it would be an issue, but I have seen a few blocks from an ice cream shipment have an effect on passengers with the windows up.
Iats where low before the last motor started to leak coolant out the head bolt
30-40 above ambient on a 2.3 wasn't terrible
I do have a killer chiller but haven't decided if it's going to be used
Only got to test the previous motor out for the short life of 1100 miles or so
have you used it with dry ice yet? It will pressurize the system and blow water out of the overflow cap if you have one. If you don't have the oem fill neck or functional pressure rated radiator cap, it can blow lines or crack things. easiest thing is to vent the flow through tank to atmosphere if its the highest point in the system, which it appears to be from your picture.
its a fuel cell cap thats vented so i assume it should vent to atmosphere unless the cap has a pressure rated release valve
hahaha yeah we won't hopefully be doing that again..
great convo at xxx mph
whats that noise?
um dude that's your engine pieces hitting the ground
lol.
looking forward to seeing this thing run though, some good races coming up this summer.
whats that noise?
lol.
Little update
Block prep will be finished sometime this week
Upgraded pistons to 11:1 diamonds with cermaic and Teflon coating
Should hold up well, price was right couldn't say no
Went with federal rssr tires as I hear for $120 a piece they stick like glue in the corners
M&h radials on in redline wheels for race day
