98lb injectors, installed and running
#51
Rent me! per hour
sorry, i giggled a bit
before the ss i had a grand prix gxp. had some zzp parts on it. actually it's the only thing that saved the transmission in that car oddly enough.
i'm talking in terms of the fuel system itself. not the motor
#53
why do i need 98lb injectors? over killing the fuel system so i don't have to upgrade later down the road. phase one of it is done. phase two is the rest of the system. enough for 700whp which i will never see. the last thing i want to worry about is "is my fuel system going to take the pulley drop? or do i need meth again?".
#54
wow thats a beefy fuel system...
return style? or zzp's fuel pump voltage mod?
#56
Rent me! per hour
on a returnless? mmmmm dunno?
jrhd - no re-wire if i can help it. return style would be so much easier to work with right now. then again, i have never done anything the easy way with any of my cars.
the zzp part on the gxp was a shift kit. intense got horrible reviews on club gp. so i went with the one that had better reviews ::shrugs::
#58
Nice work. I'll definitely be keeping my eye on your progress with this. I can't wait until I can see the pics though. Damn gov't hates me looking at cool stuff.
#59
Always 5 steps ahead...
Area. Have you been paying attention to the seasonal E85 blend changes? In September my local stations switched to the fall blend. So the fuel went from approximately 83% to 78% ethanol over the last two weeks and it has had a huge effect on my AFR in PE.
My ARF in PE has leaned out .6-.8.
More info for those who are interested:
Per federal (DOE) specifications E85 does change the % ethanol vs hydrocarbon by season. The purpose of this is to raise the Reid Vapor Pressure of the fuel for cold starts in flex fuel vehicles.
This is done by increasing the % hydrocarbon (gas component) as colder temps are expected. Here are the normal months changes begin to happen as one moves thru the seasons and the final blend % alcohol for Wisconsin's lattitude;
Sept to Nov 78%
Nov to April 70%
April to May 78%
May to Sept 83%
(% alcohol is stated in pure terms w/o denaturing gas-- thus the Summer E85 is 85% denatured ethanol but only 83.3% pure 200 proof booze).
Sept to Nov 78%
Nov to April 70%
April to May 78%
May to Sept 83%
#60
Sept to Nov 78%
Nov to April 70%
April to May 78%
May to Sept 83%
Sept to Nov 78%
Nov to April 70%
April to May 78%
May to Sept 83%
Just like switrching to pure gas while running the same injector pulses would make you rish as all hell, i would assume slightly increasing the gas content and reducing ethanol content would also make you run richer...
#62
if they're using more conventional gas, and less ethanol, wouldnt that make your car run richer? not leaner? Given that gas has a stoich near 14.7:1 vs ethanol's stoich wich is much richer.
I wonder if I got one of my tunes switched. hmmm
#65
Rent me! per hour
Sept to Nov 78%
Nov to April 70%
April to May 78%
May to Sept 83%
Sept to Nov 78%
Nov to April 70%
April to May 78%
May to Sept 83%
they are starting to switch here as well. i am working with paul yaw on two separate fuel maps right now for the 1k's. one for e85, and one for pump gas.
just let it be known that using a 60lb map for 80's, or 79's is not the way to go about tuning for e85. there is so much that has to be changed in the map. will it work? yes. work right? not really.
#67
Fail Less.
bika hes talking about me being sick in the head lol cuz ima keep goin down in sizes and u know it i think ill need 79s or 80s for the 2.75 pulley and the 7gph meth nozzle bc the pulse rate on the injectors are gonna be near static with the 60s .. 2.9 pulley is nice.. but.. not enough in the end..not in my eyes atleast
Besides, If you get 80#s or 100#s, I'm not doing your injector maps. Buy Bryan some plane tix out here, maybe he will do it. I'm not ******* trying to scale those things. FML
#68
you must not have read his post about most people never needing more than 60s. I'm 99% sure you wont need bigger squirters for a 2.75. you will be fine with your 60s and a 7gph nozzle. even with the 2.9" and no methanol you still didnt run out of injector.
#69
Rent me! per hour
i love these injectors more and more every day. the massive amount of precise control with these is flat out awesome. idling at 0% dic, cruising down the highway at 2-3%. i have not gone wot yet due to the maf work i am doing right now to get it exactly right.
something else i have found out. the avg mpg is based upon several things. injector msec/idc, fuel level, and the base of the fuel map itself. the farther you get away from stage 2. the more skewed it becomes.
i'm sitting at half a tank right now and it says i have 320 miles till empty. so, 640 miles on a tank of e-85. uh. no.
#72
wait a sec bryan, i thot the mag said by the time it was published you were going to have a ported head and forged bottom end in the car? you stated just the valve springs werent stock... are you going to port it soon or any of that?
