ABS light and P0433/P2229
Hey guys,
Issue 1
I need some help figuring out my ABS problem. My pedal is completely soft and my ABS light is on. I bled the brakes using the x pattern starting with the right rear and the pedal regained it's stiffness. Once I turned the car back on it went soft again and the light remained on.
Issue 2
I am getting P0433 and P2229. I have checked the emmisions fuse and it's good. I have also switched the map sensor plug with the similar plug in the same bundle and I still get the codes either way. Just to verify, it's the p.e.d. 4 plug that goes on the map sensor right?
Issue 3
The temp reading on my dashboard display is not showing up.
Issue 1
Issue 2
Issue 3
I saw that connector there, but I couldn't figure out where it belonged. thanks.
Any insight on the ABS?
Last edited by cobaltBlackss; 01-17-2010 at 09:00 PM. Reason: Automerged Doublepost
I Saw it when I installed my K&N intake...
Thought it was for the Airbag or something.
Just enough of a crack to let air in.
z28addiction
09-28-2015 12:03 AM
