Adjusting IFR with HP Tuners
Was wondering if someone can help me with adjusting my Injector Flow Rate vs. KPA. I posted on HP Tuners forum but no one answered. I know what I have to change but I just don't know how to do the calculations and I don't have Excel to do it. I'm running the Intense 42.5 lb/hr injectors on the GM Stage flash (GM Stage injectors are 42.06 lb.hr).
Any help would be greatly appricited.
Originally Posted by sneaky
it would be better to ask Rob or anyone at Intense this question. I'd call them
Highlight the entire IFR table , and then times it by 1.363 . This is only if you do not have the GM stage 2 reflash for the bigger injectors (as far as I know because it should already be recalibrated then ?) . This will work if you are going to a Lucas/Delphi 42 lb. injector (which actually flows around 49 lbs. per hour in the cobalt ss because the 42 lb. injectors are flowed at 43.5 psi and the lsj runs at 58-60 psi) .
Mike
Mike
