Advice for Getting Belt Over SC Pulley? (Hands are destroyed!)
Well, got everything installed from my stage kit. The kit included a larger tensioner pulley to compensate for a 2.8" SC pulley.
So, I'm at the last step: getting this damn belt over the new SC pulley. Even with the tensioner relieved to what I think is max (using a wrench pushing towards engine block), it's a mother to try and get this belt over the SC's pulley. I'm sure it will fit, it is going to be snug as expected, but damn, it's hard as hell to do this.
Any advice on getting that belt over? I was thinking of actually unbolting the SC, putting the belt over the pulley, then using the SC itself as leverage to bolt the SC back in place with the belt already set. Anyone tried this?
I find the stupid wrench keeps slipping off the bolt, any ideas for dealing with that aslo?
Thanks a lot!
Thanks a lot!
I used a 1/2inch drive power bar wedged in the motor mount to depress the tensioner. If that doesn't work you can unbolt the SC to tilt it a bit then tighen it down after belt is on correctly.
Edit: if you use something to press down on the tensioner pulley like I did, make sure the belt is on it first so you don't damage any ribs on the pulley.
Thanks guys, just not sure what you mean by "power bar wedged in the motor mount to depress the tensioner", please elaborate.
Thanks so much, appreciate any advice!!
Got Bewst?
I run a GMS2 shorter belt WITH and oversized tensioner and can get it on no problem. Make sure the belt is sitting on the pullies properly down below. That's probably why it's difficult going on. As for the wrench slipping off, take a 9/16's and tap it on with a hammer. It will never slip off again.
Thanks everyone, I managed to get it on, here's how I did it:
I relaxed all 4 SC bolts by almost 3/4 inch. I had my wife (she's strong) pick up the intake end of the SC and this allowed the hub to angle down. I then put my 9/16's wrench on the tensioner bracket, compressing the tensioner. This allowed a lot of slack, considering the snout was already angled down, and the belt slipped easily over the SC pulley.
To finish up, I kept the pressure on the wrench, compressing the tensioner, while the wife tightened down the 4 SC bolts. Perfecto! Warning: do not let off pressure on the tensioner before the SC is fully bolted, the SC will lift and you'll have to wrangle it back in place with a bit of muscle. Be careful not to bend any bolts/engine hardware.
