Aftermarket Cylinder Heads for LSJ
#51
You don't know if I'm wrong now do you? You have no idea where I stand on this other than I think you're a dick, which you keep proving for me and admitting to. Besides you can get a point across without insulting someone. That's all I'm saying.
#52
#53
I like the idea of a patriot head...iirc they do good work...but imho if i owned their company id be pissed at u in the way u are handling this. But i am interested pending flow numbers and prices.
#54
#55
Just a lil fyi for everyone from page 68 of gmpp ecotec build book compare the numbers at .450...also notice the patriot heads have slightly larger valves...same flowbench btw...at the end are gmpp lsj head flow numbers...also uses valves smaller than patriot
Dan
SPORTSMAN CYLINDER HEAD FLOW
SPORTSMAN CYLINDER HEAD FLOW NUMBERS - PERFORMED ON A SUPERFLOW SF-1020 FLOW
BENCH
Intake Valve Test Data at 28.0 Inches of Water
Valve Lift (in.) 0.050 0.100 0.150 0.200 0.250 0.300 0.350 0.400 0.450 0.500 0.550
Corrected Flow 45.5 91.2 131.6 169.5 202.4 235.0 257.2 267.0 273.1 276.3 280.8
SPORTSMAN CYLINDER HEAD FLOW NUMBERS – PERFORMED ON A SUPERFLOW SF-1020 FLOW
BENCH
Exhaust Valve Test Data at 28.0 Inches of Water
Corrected Flow 39.0 85.4 123.5 156.8 180.6 196.2 202.5 207.3 210.2 213.4 215.6
From patriot performance site stage 2 head
Stage II Heads
5 Axis CNC Ported
Patriot Gold Springs
Patriot +1mm Valves
Bronze Guides
Ti Retainers
5 Angle Valve Job
1020 Superflow Bench 3.530 Bore
Lift
1.420" Intake Valve
1.225" Exhaust Valve
.050
41 cfm
38 cfm
.100
81 cfm
77 cfm
.150
121 cfm
109 cfm
.200
162 cfm
138 cfm
.250
190 cfm
160 cfm
.300
217 cfm
174 cfm
.350
230 cfm
183 cfm
.400
254 cfm
185 cfm
.450
265 cfm
189cfm
Part #
Description
MSRP
2041
Ecotec Stage II Bare
$1,095.00
2042
Ecotec Stage II Assy (w/o cams)
$1,295.00
LSJ STUFF GMPP CNC
RACE CYLINDER HEAD FLOW
RACE CYLINDER HEAD FLOW NUMBERS – PERFORMED ON A SUPERFLOW SF-1020 FLOW BENCH
Valve Lift 0.050 0.100 0.150 0.200 0.250 0.300 0.350 0.400 0.450 0.500 0.550
Corrected Flow 43.1 86.3 125.4 165.5 204.2 233.5 254.1 269.6 281.2 224.4 288.7
Corrected Flow 37.1 84.7 125.7 162.6 189.8 201.4 208.3 213.7 217.6 220.7 222.7
Dan
BENCH
BENCH
Stage II Heads
5 Axis CNC Ported
Patriot +1mm Valves
Bronze Guides
Ti Retainers
5 Angle Valve Job
Lift
1.420" Intake Valve
.050
41 cfm
38 cfm
.100
81 cfm
77 cfm
.150
121 cfm
109 cfm
.200
162 cfm
138 cfm
.250
190 cfm
160 cfm
.300
217 cfm
174 cfm
.350
230 cfm
183 cfm
.400
254 cfm
185 cfm
.450
265 cfm
189cfm
Part #
Description
MSRP
2041
$1,095.00
2042
$1,295.00
LSJ STUFF GMPP CNC
#56
The entire point of this post was to gather and guage interest in a cylinder head thats built and ready to assemble for under 1500 which currently does not exist on the market, For a product comparable to a patriot stage 2 head like they make for the L61 you would have to go through JBP and spend 3000, I know alot of you may love that company however its possible for you to build a head yourself at a local machine shop for a whole lot less than what JBP sells anything comparable.
Again I'm not trying to Bash anyone or any company but JBP pricing for what your getting is simply not competitive. I can see this crowd is only a slight bit above in the stupidity level of JBO. You should be more open to learning about your cars and options for them as well as listening to people who have worked with the ecotec motor 4 years before your car existed
#57
I am more than interested in Patriot making an LSJ head. I don't think anyone said that they wouldn't want a quality product made for our car. The problem is you. I have been interested in upgrading my valve train and porting the head on my engine since I bought the car. The reason I haven't got one yet is that I haven't found a fair price. I will buy a head from patriot if they make one. I will never buy one from you. That's the same reason I would never buy a Glas-Tek hood from you. Glas-Tek has nothing to do with it. People want to buy products from knowledgeable people. This is true. People don't like to buy from people they dislike. That is also true...
#59
Dan
BENCH
BENCH
Stage II Heads
5 Axis CNC Ported
Patriot +1mm Valves
Bronze Guides
Ti Retainers
5 Angle Valve Job
Lift
1.420" Intake Valve
.050
41 cfm
38 cfm
.100
81 cfm
77 cfm
.150
121 cfm
109 cfm
.200
162 cfm
138 cfm
.250
190 cfm
160 cfm
.300
217 cfm
174 cfm
.350
230 cfm
183 cfm
.400
254 cfm
185 cfm
.450
265 cfm
189cfm
Part #
Description
MSRP
2041
$1,095.00
2042
$1,295.00
LSJ STUFF GMPP CNC
Dan
BENCH
BENCH
Stage II Heads
5 Axis CNC Ported
Patriot +1mm Valves
Bronze Guides
Ti Retainers
5 Angle Valve Job
Lift
1.420" Intake Valve
.050
41 cfm
38 cfm
.100
81 cfm
77 cfm
.150
121 cfm
109 cfm
.200
162 cfm
138 cfm
.250
190 cfm
160 cfm
.300
217 cfm
174 cfm
.350
230 cfm
183 cfm
.400
254 cfm
185 cfm
.450
265 cfm
189cfm
Part #
Description
MSRP
2041
$1,095.00
2042
$1,295.00
LSJ STUFF GMPP CNC
#60
#61
Originally Posted by hypsy
GM's flowbench is from an LSJ head while Patriots are on a L61 head. Can't even compare the numbers bud. I have both numbers written side by side in my build book though just so I know what I needed to get. Oh and the GMPP head is designed for bigger valves BTW last I checked.
No both are a superflow 1020 bench I was comparing 2.2 to 2.2..the 2.0 numbers were at the end
They are different number, which i listed for both. The first set is from a lost foam cast 2.2 head..the second is from a sand cast lsj head. GM cnc heads use lsj valves which at 1.400 and 1.200" respectively. patriot is 1.420" and 1.225". All from the build book and patriots web site
Dan
#62
Originally Posted by Witt
To be blunt as you put it...do you have any idea what you're talking about?
So then....do YOU have any idea what your trying to contradict me on?
#63
Yes I do actually. Would you like to tell me how you can compare the numbers from a L61 head and a LSJ head? They are two completely different heads and two completely different casting methods so you can't. Maybe you didn't know but the GMPP Race head is just a P'n'P LSJ head. I know....because I just had to get all the info on every GMPP race part for my new project.
#64
You talk to Matt like he was part of my company or something. Matt doesn't work for me. He is just a person who is actually trying to do something different and make his car fast.
#65
Dan
Dan
#67
What the hell are you talking about? The only person I have addressed in this thread has been you. Who the hell is Matt? I have not said one thing to or about "Matt." Get your facts straight...
#68
My apologies for you not being able to read.
EDIT: That remark was below the belt, I apologize. This kinda **** just gets me wound up. I figured the Glas-Tek comment would make it more than clear who I was referring to.
#69
Yes and he is misinformed. All the GMPP heads are based off LSJ heads.
#70
Well I'm just going off what I was told in my recent talks with them. I'm working on a new project and I need a lot of their parts so I was discussing a lot of stuff with them. This was one of them.
09-28-2015 12:51 PM
