air conditioning
Old 09-27-2009 | 04:25 PM
K0ba1t 5s's Avatar
air conditioning
y isnt my air conditioning not working, it blows air, but all it is, is the fan, what r some of the reason y it isnt working
thanks
Old 09-27-2009 | 04:37 PM
ssyellow's Avatar
....are you asking why its not "cold" air?
Old 09-27-2009 | 06:01 PM
More_Torque_More_HP's Avatar
thanks
Doyou have GMPP Stage 3? If so the AC is disabled because it is off road use only.
Old 09-27-2009 | 06:15 PM
Zach06CobaltSC's Avatar
You might need to recharge the a/c.
Old 09-27-2009 | 06:46 PM
Winkdogydog101's Avatar
does it help
does it feel like its blowing out fast? if not then its the in cabin filter. if you thought your vents and its cold ac is fine your filter is just cloged. if it blowing good and is just normal 80% of the time it needs recharge also if your air is noram and weak REPLACE THEM BOTH
Old 09-27-2009 | 07:12 PM
K0ba1t 5s's Avatar
well its a new filter, but ill try that, i dont have a stage 3, and yes im asking y it isnt cold
Old 09-27-2009 | 07:59 PM
leviticus88's Avatar
Start engine, Turn AC on and pop hood, see if the AC clutch has engaged and the compressor is moving. Middle of the pulley will be moving. Might try having someone in the car turn it on and off and see if that changes anything you see on the pulley.
also, take to a shop and have them recharge with refirgerant.
Old 09-27-2009 | 08:02 PM
K0ba1t 5s's Avatar
where is the ac clutch and what am i looking for
Old 09-27-2009 | 08:04 PM
buellfooll's Avatar
Sounds like it needs some attention from an AC shop.
Old 09-27-2009 | 08:07 PM
Agreed
Find ac compressor, the clutch is on the pulley driven by the belt.
Old 09-27-2009 | 08:09 PM
ssyellow's Avatar
could need a recharge of freon or what ever that stuff is called....
Old 09-27-2009 | 08:55 PM
K0ba1t 5s's Avatar
ok ill do those things, im lucky casue i have about a year until i need air conditioning again lol, until then windows will be down
thanks
Solaris99
28
03-15-2017 02:22 PM
hacadacalopolis
10-28-2015 07:09 PM
no_ss
10-19-2015 12:58 AM
DocSvensk
09-27-2015 03:24 PM
OrangeCoba
09-25-2015 07:06 PM
