Alternator pulley removal
Is there a trick for the LSJ Alternator pulley removal?
Removed the small plastic coverplate but I'm not sure if the 10mm hex piece is some kind of locking bolt/nut? Or is that to hold the shaft while the pulley is turned loose? (and what direction should it be turned loose?)
Thxs.
Thxs.
.... theres 3 bolts that hold the alternator in place. 2 on top, one on bottom.
righty tighty, lefty loosey...
https://www.cobaltss.net/forums/how-guide-43/hunters-how-install-m62-2-2l-cobalt-127891/
scroll down to alternator removal
