Anybody got Cams?
Anybody got Cams?
You dont really ever hear about anyone having the cams that are out for our cars. If you do. What do u think. and a sound clip would be huge!!!!!
Yeah, whoever has cams, could you please get some video of it, or sound of it starting up and idling, and if you dynoed the car with them, could you post up the dyno sheets???
Yeah but i know of at least 3 people i have heard who have cams. I think right now its a risk to go with the cams. but then again. everyone is so caught up in the stage kits
GMPP and COMP CAMS
GMPP has a cam set and COMP CAMS has 5 different sets of cams. http://www.compcams.com/Technical/Ca...2006/Page1.jpg
I think that girl on here that's holding the NY tag has cams!!??
Scott
Scott
I got JBP Stage 2 Cams,
but they will require tuneing. I get a non-performance effecting code. (info on JBP site)
but my car is stock except for the cams, and the cams cause the supercharger to over boost, and the by-pass valve dumps the boost back to stock levels at about 5600RPM from 100kpa to 87kpa (14.6 to 12.5).
plus side is, I make stock HP about 1000RPM sooner. (dyno on JBP site)
I tried the boost by-pass mod, and and the car pulled much harder, and I hit the rev limiter much quiker at about 110Kpa ( 16psi). I'd leave the mood but I'm worried about leaning out.
Originally Posted by spooler
i recently got a code, but dont really care, since i have a power gain. never tuned them, dont know how. i got 12whp w/my cams.
Hey turbo Tech. if i got the stage 2 or 3 cams. would i need valve springs or any other product to go along with it? also. how much is a basic install for these cams on our cars?
Install IMO would take about 2-3 hours, so $150-250 range i would guess to get installed.
The ecotec cams are actually easy to change, well atleast to the 2.4L LD9 out of the Cavalier.
If you dont want computer mods i would not recomend getting the stage 2 or 3.
You might get away with the stage 2 with no valve springs, but i know for a fact you need them for the stage 3 as we have them (in a 2.2L Ecotec).
Originally Posted by JCswoosher2
so your saying your having problems with your cams?
the code I get is the P0017 NOT P0171.
the P0017 can only be read with the Tech 2, and then had to be looked up on the computer ( dealer data base). P0017 as a code indicating that the Cam angle, is different then the Crank angle, it has to do the way the cam is made. this is also directly related to the starting problem I'm haveing.
