Anyone add a second stock heat exhanger up front?
Old 07-19-2006, 09:02 PM
  #126
pierre's Avatar
Originally Posted by ENUFPWR
Here are some more results on a colld night.
Last nights results:
Outside temp 77degrees
IAT1 81degrees
IAT2 98degrees
While driving light to light normal traffic.
Let standing in a parking lot for 10 minutes at idle....
IAT1 82
IAT2 109
Coolant temp 181degrees steady...
Highway driving home.....
IAT1 82 degrees
IAT2 99-101 at 80 mph
1st through 4th gear acceleration from a dead stop on the highway....
IAT1 82 then slight rise to 83
IAT2 temps 99-130 first 3 gears
4th gear....143-145 max at 125mph before shutting down.
costing to 60mph temp rise to 150 then cool as soon as I give it throttle.....beack to 109 then going 80 IAT2 temps stabalize at 100
Damn... this I never did see sup 100 IAT2 temps before...so I'm more then happy with this setup. I haven't even put on the extra coolant tank or an ice box. Not sure if I have to anymore..
Thanks for getting more data.
Comparing AIT1 to AIT2 at the top of 3rd gear on the acceleration run looks like it yielded a 48 degree difference ( my benchmark for intercooler efficiancy). Correct? Now for bonus points run the coolant to the two exchangers in parallel instead of in series. This will decrease the system flow resistance the pump sees and there will be a higher flow rate. This will reduce the heat transfer in the exchangers but it will increase the flow through the Laminova's therby increasing heat transfer. It all depends on which one is the limiting factor.
I doubt it will make much difference but it woulld be an interesting experiment and someone is going to ask eventually.
Thanks
Pierre
Old 07-19-2006, 09:56 PM
  #127
Doc
Doc's Avatar
Thanks
Pierre
Let me get this right.
You mean splitting the line going into and out of the heat exchangers?
Kind of like 'T' or 'Y' fittings at each end?
Old 07-19-2006, 11:29 PM
  #128
pierre's Avatar
That is correct. Using two idetical exchangers the flow resistance should be the same therefore flow will be equal in each one in parallel. The flow resistance of a pair piped in parallel will be half of a single unit. It's not something I would try with the Ford cobra exchanger others are experamenting with though.
Pierre
Old 07-20-2006, 12:52 AM
  #129
patathSS's Avatar
Some numbers I have of the Cobra Heat exchanger. This pull was a 1-3 gear run 0-108mph run.
At start IAT1 is 106, IAT2 is 113.
At 1-2 shift IAT1 is 105, IAT2 is 118.
At 2-3 shift IAT1 is 114, IAT2 is 144.
At the end of third IAT1 is 122, IAT2 is 162.
This was the hotter of the two runs. the other run I logged with my Interceptor and saw 149 as a high IAT2 temperature. But I did have some knock on the first run with the Interceptor where as the second run was knock free.
I think with fans for the Cobra heat exchanger this could be even more effective. Also, I am unsure if it is possible to upgrade the pump but that may be a possibility.
Old 07-20-2006, 07:49 AM
  #130
pierre's Avatar
Thanks for posting your data.
I have a couple of questions.
What size blower pulley are you using? The smaller the pulley the higher the post blower temperature is going to be.
Your AIT1 seems high. What was the ambiant temperature? If you look at ENUFPWR's AIT1's they are 3-5 degrees above ambiant for all his tests. Yours seem higher. What intake are you using? Cold air or not?
If the Cobra exchanger is mounted well forward of the radiator/A/C condenser/heat exchanger assembly there is a possabilty that the Cobra HE is heating up the air going into the engine intake hence high AIT1's.
Pierre
Old 07-20-2006, 10:55 AM
  #131
patathSS's Avatar
Pierre
I am running a 2.5" pulley. It does generate a ton of heat.
I am not sure why my IAT1s are so high. I noticed it too since normally they are close to ambient temperature. Ambient temperature was around 80. I have a cold air intake but I am not sure how the Cobra heat exchanger would affect it since it sits in the wheel well.
Old 07-20-2006, 11:59 AM
  #132
pierre's Avatar
ENUFPWR is running the same size pully so the data was taken at similar conditions.
My guess at the AIT1 temperature rise. Unless the Cobra HE is ducted to the Radiator/A/C condenser/heat exchanger assembly so all flow goes from the nose/motor bulkhead area to the engine compartment you are heating up the air behind the Cobra in the common front area where your air intake happens to be.
ENUFPWR is running a stock HE directly in front of and tight to the A/C condenser. All the hot air goes through the stack and into the engine compartment and his AIT1's stay low.
Pierre
Old 07-20-2006, 01:08 PM
  #133
vandy0419's Avatar
I am making the brackets finally tonight for the LFP HE and won't be able to actually test out the temp drop just yet. BUT I will be adding in the coolant chiller that was released by DEI...they're only $9 a bottle with free shipping and you just mix one bottle in...I bought 3 because I will have the ice box and HE in eventually.
Old 07-25-2006, 10:16 PM
  #134
pierre's Avatar
Just to add a little extra data....
IAT1 81degrees
IAT2 98degrees
IAT1 82
IAT2 109
IAT1 82 degrees
I ran accross a data log of a 1/4 mile drag run you posted on another list. It seems to have been done before you added the second HE.
Ambiant seems to be about 82 ish judging from the 86 F AIT1 down the track.
At the start
AIT1 104 F AIT2 131 Got a little hot in the staging area !
Top of second
AIT1 90 F AIT2 153
Top of 3rd
AIT1 86 F AIT2 178
Boy does that 2.5" pully heat things up.
I know the two runs are not exactly apples to apples but compared to your posted data above this is a significant improvement in intercooler efficiancy. Seems like the Laminova's have plenty of extra heat transfer capacity to take advantage of the additionl HE.
Sweet
Pierre
Old 07-25-2006, 11:45 PM
  #135
ENUFPWR's Avatar
Thanks for the good comparison Pierre
Old 07-26-2006, 12:55 AM
  #136
selfinfliction's Avatar
man that's pretty high.
edit: didn't know you were running a 2.5" guess it's not that high
Old 07-26-2006, 01:09 AM
  #137
FAST06SS's Avatar
Just posted this in my thread but will add it here.
Just installed a custom 2nd heat exchanger, looks sinilar to the Cobra HE.
With this and water injection, 80deg ambient, I had a IAT2 temp of 127 degrees on 0 to 100mph blast!
Car felt really strong!
Old 08-02-2006, 08:29 AM
  #138
denny's Avatar
Bump for an update.
Old 08-02-2006, 08:42 AM
  #139
06blackg85ss's Avatar
I should be installing a different custom made lfp h/c on friday if it comes in on time... I was wondering If I could just run that and delete the stock heat exchanger all together to free up some space on the radiator.. It measure 20x7x3 and I will be installing 2 fans on it on a switch inside the car... also installing a larger resovior and braided lines with larger an fittings.... hopefully I'll have some data to post this weekend... just looking for some opinions... and if all goes well I'll be selling the stock h/c if anyone is interested.
Old 08-02-2006, 08:58 AM
  #140
patathSS's Avatar
Why not? I don't know how hard it would be to pull the stock HE but you could try. Hell, only a few ppl have done this so you might as well experiment and see what works best.
Old 08-02-2006, 09:02 AM
  #141
vandy0419's Avatar
Yes, you can just remove the stock HE from the flow, but what do you mean free up space on the radiator? The stock HE is between the AC condensor and the radiator and the stock HE is small.
Are you sure it isn't 20x6x3? That is the size of the one I got and it is the same one they already market out for the Cobra.
Old 08-02-2006, 09:28 AM
  #142
dunno... 20x7x3 is the measurements I was givin from lfp... but I"ll check when he gets em in.
Old 08-02-2006, 09:33 AM
  #143
vandy0419's Avatar
Here is my LFP HE!
Old 08-02-2006, 12:04 PM
  #144
SS33's Avatar
Looks nice
too bad you hafta have that plate covering up some of it
Old 08-02-2006, 01:11 PM
  #145
vandy0419's Avatar
Originally Posted by SS33
Looks nice
Yep, sucks to live in OH! Have to have a front license plate and it has to be centered!
Old 08-02-2006, 01:14 PM
  #146
I'm gonna adjust mine to clear it up, bend it and move it up if possible.... I hate having the bumper opening being blocked.
DarrenGC
Forced Induction
01-02-2016 09:10 PM
Jimmy Beilfuss
10-05-2015 04:18 AM
09-27-2015 08:53 PM
09-26-2015 06:44 PM
Dirtybutwhole
09-26-2015 03:29 PM
Quick Reply: Anyone add a second stock heat exhanger up front?
