bad boost need help
bad boost need help
I have a 06/sc with gm stage 2 cai, catback. All i see is about 10 psi, i did the bypass mod and hit 12.5 tops. So im thinking bad bypass maybe belt slip 50,000 miles, my iat 2 are 138-145 and 5600 elevation maybe thats why im unable to hit the 15 i suppose to. Or could there be any reason why boost so low.
bump?
bump?
my only guesses would be belt slip and the thin air could possibly cause that..less pressure.. less psi doesnt mean less power neccesarily
does it feel strong or does it feel like it should have more??
If it was belt slip you would know. when i had my SC belt slip would happen and throw me forward in my seat. Maybe bad gauge, vacuum line pinched/collapsed, gasket leak, improper tune.
pump working, before pull its 100 hear at like 6 at night so hot hot. Im doing fuel filter new plugs header dp heat exchanger new bypass. See how it is after that
