Balance Shaft Delete Kit
Old 03-07-2012 | 08:17 AM
mongorat427's Avatar
Originally Posted by mrbelvedere
what you did was a permament mod also by opening up that oil galley but still a cheap and decent way of doing it
the balance shafts were put in the engine for driver comfort they do nothing for the balance of the rotating assembly
Actually its not permanent if you later wanted to put balance shafts back in for whatever reason. Just remove the 1/8 allen and put a new set of bearings in if you have the kent moore tools like I have. The bearing only allows enough oil out of the galley to lube the shaft journal. Most people would never revert back.
The 3/8 hole can also be used for an oil return line if needed.
Supercharged06SS
12-11-2022 04:47 PM
05-28-2022 03:47 AM
dennis69
10-20-2015 04:49 PM
DANRICKARD
10-01-2015 12:08 AM
09-28-2015 12:51 PM
Quick Reply: Balance Shaft Delete Kit
