bates sleeved blocks
Old 11-17-2011, 01:10 PM
  #126
slvr 04 rl's Avatar
Originally Posted by Leafydialupking
ARP studs, if you lifted the head, you should certainly run them.
i am aware of that. ive already got a set..as well as everything else for a built engine. but i dont want to put it all together and have a sleeve go out and ruin what ive got already.
Old 11-17-2011, 03:51 PM
  #127
mrbelvedere's Avatar
other then assembly the second relability factor is the tune plenty of people have made big power on all stock stuff and it has lived a happy life
Old 11-17-2011, 05:18 PM
  #128
ebristol's Avatar
Dam.
http://shop.zzperformance.com/store/...led-Block.aspx
Thank you ZZP!
Old 11-17-2011, 05:22 PM
  #129
InfraRedline's Avatar
Originally Posted by ebristol
I was on the site last night looking and the info wasnt up...guess I looked just a tad too early
Old 11-17-2011, 05:29 PM
  #130
"- Zero sleeve/girdle failures to date"
how many are really running around putting miles/passes/dyno runs on these motors?! lol
Old 11-17-2011, 06:07 PM
  #131
more then u think
Old 11-17-2011, 06:13 PM
  #132
ebristol's Avatar
Turbo 2.4L stroker.
504whp on pump gas at zzp - Saturn ION RedLine Forums
TVS 2.4L stroker
PistoNHead's official build thread. - Saturn ION RedLine Forums
Plus all the ZZP cars.
Old 11-17-2011, 07:39 PM
  #133
SC07's Avatar
As reference for all, GMR did not "fail" at the girdle design, they simple went with the sleeved route because of time constraints. To me that's not a failure to do the girdle so much as they just didn't see it through and went another route. Take it as you will though, not intended to bash ZZP or anyone else, they just seem pretty insistent about how GMR failed, where they succeeded.
Old 11-18-2011, 12:07 AM
  #134
ebristol's Avatar
I don't want to speak for Zooomer but I think he was referring to GMRs attempt at installing a girdle in a ecotec. I don't think he was referring to the original design but more of their attempt to make it stronger by filling certain parts of the block to improve strength.
But I could be wrong.
Old 11-30-2011, 04:53 PM
  #135
VeNoM0713's Avatar
I'm Not really on the forums anymore because I just don't have the desire to mod my car anymore. Mostly due to the fact that I have a bates block in my balt that is leaking coolant into my oil. He fucked up almost everything on my block. I think I would've been better off doing the work by myself. But anyways, do yourself a favor and stay away from bates.
Old 11-30-2011, 09:05 PM
  #136
slvr 04 rl's Avatar
damn, sorry to hear that. i guess he isnt taking care of anything either?
i plan on just getting the zzp block after the new years
Old 11-30-2011, 09:11 PM
  #137
AyrtonSenna's Avatar
Is it possible to install the Dartons and having the ZZP girdled block?
Old 11-30-2011, 09:28 PM
  #138
mexi_loco's Avatar
^^^wouldn't that be a bit overkill??? just saying, not too mention what would be the point?
Old 12-01-2011, 12:53 AM
  #139
Leafydialupking's Avatar
No. The dartons take up the area that gets the girdle because the zzp girdle is really a block guard and not a girdle. I mean all ecotecs have a girdle stock, its just integrated into the oil pan.
Old 12-02-2011, 09:34 AM
  #140
Supporting Vendor
Zooomer's Avatar
GMR stated that they did sleeve the Ecotec and it resulted in piston skirt and cylinder bore wear issues. I was going by what they said and did.
I haven't heard this about all the Bates engines, but I do know it's very common on sleeved engines no matter who builds them. It was on the engine I have pics in this thread of. It's why you don't sleeve Ecotecs with the girdle available people! I'm not sure why this isn't sinking in with everyone. Someone asking if you can do both? Why so you can have a motor that's weaker and risks leaking coolant and for certain runs hotter?
Old 12-02-2011, 09:40 AM
  #141
I'm fully with zoomer on this one. The zzp block guard makes way more sense than the sleeve options. Its much less evasive to the block, lighter, just as strong.
Did you guys think of making an aluminum version of it? It would cool even better, be lighter, and should be almost as strong as the steel. The big concern is, press fits of aluminum into aluminum scare me since they can gall each other going in. At least you would only gall the girdle going in since the block would be harder and more abrasive than 6061 because of the high silica content.
Old 12-02-2011, 10:17 AM
  #142
it is aluminum
Old 12-02-2011, 10:20 AM
  #143
It was hard to tell in the picture. I made the safe assumption that it was steel.
Old 12-02-2011, 10:28 AM
  #144
steel would work but very well and more then likly cause leakage problems
Old 12-02-2011, 10:39 AM
  #145
And more possibly more core shift under heat cycling (or possibly less). Interacting press fit metals in a heat cycling environment do funny things some times.
Old 12-13-2011, 05:47 PM
  #146
EXsoccer1921's Avatar
i've got about 6k on my setup. who knows how many pulls on the dyno for tuning and on the street. plus 1.2k of those miles were a 23 hour trip from michigan to kentucky and on to oklahoma. actually come to think of it i've made that trip twice now on girdled blocks.
Old 12-13-2011, 06:09 PM
  #147
RooTBeeR's Avatar
f u...think your all cool and ****
Old 12-13-2011, 07:53 PM
  #148
watch it buddy....
lulz
Old 12-13-2011, 08:12 PM
  #149
mexi_loco's Avatar
**** you! i want zeh mod status!
05-28-2022 03:47 AM
ineedacobaltss
11-07-2015 02:25 PM
HEATON
10-16-2015 07:21 PM
Trav3480
10-01-2015 08:17 PM
anotherslowlnf
09-29-2015 03:52 PM
Quick Reply: bates sleeved blocks
