Best Meth Kit?
Best Meth Kit?
I need opinions, which Meth kit is better AIS or Devils Own? I'm using it to increase the octane to run 100 Octane Mode on a Stage 3 PCM. Any opinions based on experience please!
AIS, trunk kit for easiest install. everything is preassembled. i dont have any experience yet but ive been researching the different kits. i like the ease of the install with the trunk kit and everything is tested before the send it to you.
the stage 3 pcm was never cal'd for meth. dont relate to nos. Trunk mount is the way to go IMHO. Josh can help you with both kits, the excellent devils own nozzles, and tunes...one stop shopping and he knows the product and the results...
Non Authorized / Non-Supporting
Hmmm, sorry to hear that. This doesn't happen very often. Gives us a call and we will simply replace the fitting which is leaking for free. All of our customers receive a lifetime warranty with every system purchased from us.
As for our fittings. We use some of the highest quality quick connect fittings in the industry. e do not use plastic quick connect fittings as others do. We use nickle plated brass fittings. These actually cost us quite a bit more then the plastic quick connect fittings. Additionally, we offer stainless steel hose upgrades. This replaces the plastic fluid line andquick connect fittings with heavy duty -4 stainless steel braided hose and AN fittings.
