Blower heatsoak and 2.8" pulley
ive decided im gonna go the HE route, im too scared to run water meth,
im checkin out the cobalt additction heat exchanger, looks pretty straight forward and its proven to cool intake temps, maybe after that get some of those goodies from the GM stage 3 if you can buy parts seperate.
Originally Posted by 1BADSS/SC
can you run just straight water ( distilled ) instead of payin big bucks for meth?
Methanol isn't that expensive. My buddy owns a small engine business and always has it in stock. Even retail on it isn't that bad. If you want to play, you got to pay somewhere.
Originally Posted by sethallen
i talked to a mechanic I know and he said that most engines won't last 20,000 miles if you are running water or meth injection
Originally Posted by Bad06SS
What happens when your stock intercooler pump takes a crap?
"with running water/meth injection, you are risking detonation and catostrophic engine failure shoud you system fail or not run at optimum efficiency. This is due to the fact that when tuned you will be running advanced timing, boost and leaner fuel trims that would normally not be possible without water/meth injection. Loss of the system while under heavy load may not be able to be compensated for in time, and could cause detonation at best case, and engine failure at worst case."
Originally Posted by p7x
Not this...
well guys Ive decided to not use water/meth injection. I would like to keep my engine intact and will use other means of cooling. I have an idea for a hood that forces air over the top of the engine and SC through means of multiple hood scoops.
Im going to buy a rk sport hood and do some chopping next year
I figure direct air flow over the engine and SC should drop temps drastically, especially at higher speeds.
#36
I don't think it will make much of a difference. The heat is happening INSIDE the sc and engine, which is made of metal. Blowing air on it might cool it down a little, but the power will be used up compensating for the extra drag from the hood.
#40
damn you guys are paranoid... these meth systems have been in use for over 50 yrs..(ran them on fighter planes in WWII). you have nothing to worry about if the system dies out... as long as you don't run an extremely agressive tune on your car... If you want to.. thats just the risk you take... all's fair in the game of speed...
#41
#43
1 Post
No2
on a side note - if you really dont like water/meth and want to cool things down beyond a heat exchanger then go NO2. more power and it cools. just go with a 25 or 50 shot. thats it. you can tune for it or not. go wet injection. most of the heat build up can be reduced from reducing the temp of the intake manifold. this cooling effect will suck heat away from the charger and motor. all seem like good ideas.
