Bolt Pattern Question (Pls help)
I'm looking at buying some snow tires off of a guy that come with rims. Everything seems to be a fit but im just not sure if the bolt pattern matches.
Looking at it, we have the same 5 bolt pattern but I've been told that its not just how many bolts and they way they are laid out, different cars have different spacing and therefore different fits.
He had used them on a 2001 Audi A4 previously.
The rims are labelled as mutli fit steel wheels.
Thanks a lot guys
Thanks a lot guys
They won't fit if they're off an Audi A4, different bolt pattern (5x112), you need to find 5x110, try searching for SAAB 9-3 or 9-5 wheels, those seem to be the most common for our bolt pattern. You might find a stray Catera, G6, or newer Malibu set too.
Originally Posted by Peter777
awwww, it was such a good deal too
Its not worth it if I gotta take them off the rims, then buy new rims and havem mounted.
ty for the help though. !
This bolt pattern sucks...I'm already looking at going with a custom wheel manufacturer so I can get something I want. There's one I've talked to that I'm working on sponsorship with that may let me design my own set.
5x110 sucks, not many companies make them, and at the time most of the decent companies that make wheels you have to buy 10 sets of 4, for the wheels i wanted that's what i got told and 40 wheels at 500 a piece, it just ain't happening... goo luck to all looking for snow wheels and tire, or just replacing factory....
