Boost Bypass Mod Needed With Stage Flash???
Is anyone running the boost bypass mod with the stage kits reflash and a smaller pulley? I have not really looked to see if it makes a difference, just wondering if anyone knows for sure?
That's an awsome question, I would like to know too. The only thing is I have stage 2 and during WOT! the boost stays at 15psi. The bypass mod has been used b/c some peoples boost would fall back down to 12.5 after a few seconds. Maybe the gm reflash fixed it?
360 L337 User
your only getting 15 with the stage 2?
Originally Posted by ninja44
The reflash removes the bypass limiter, with a 2.7 I boost at 140 Kpa at redline.
Holy **** thats alot of boost.
Im getting 115 with the 3.
BLKSS you have GM stage 2, what do you mean it sounds low? That is exactly what we are supposed to get. If you are getting more with the 3" pulley, your cat is blocked up.
