Boost Control
Old 05-02-2007 | 02:45 AM
scottw03's Avatar
Boost Control
How do you guys control what boost you run on the car? Can you use boost controllers with a SC? or does the pulley set you at a certain level of boost and you are stuck there unless you upgrade the pulley?
Sorry, never looked into SC's before only turbos so this is a stupid question but just wondering how you guys raise or lower your boost.
Old 05-02-2007 | 02:48 AM
$uperman's Avatar
your boost is controlled by the size of your pulley
Old 05-02-2007 | 04:06 AM
martinsmu's Avatar
Hp tune can limit your boost in certain gears, however you need to spin ure SC fast enough to create max boost before you let it bleed.
Old 05-02-2007 | 06:23 AM
NJHK's Avatar
Just to also clarify...
Boost controllers are for turbocharged systems. What it does is delay the actuator signal to the wastegate making it open later...hence your turbocharger will be spinning faster before the exhaust flow is diverted to maintain a certain turbine speed. The more delay, the more boost that can ultimately be created.
Old 05-02-2007 | 11:16 AM
Area47's Avatar
Rent me! per hour
you can limit the boost in the first and second gear with HP tuners.
i have mine set at 10 psi in first gear. helps a ton! second is wide open, i dont have traction issues in second.
Old 05-02-2007 | 12:39 PM
scottw03's Avatar
LOL, that is because you are only pushing 233 ft of torque. LOL Just kidding. Those aren't bad numbers for a cobalt 260 something hp. not bad.
Try my car with over 350 ft of torque on the stock size rims and all season tires. Trust me, you will have traction issues in 2nd. LOL
Ok, so what I see at the moment is that you are restricted to whatever max boost based on size of the pulley you are running. That kind of sucks. Ok, good info to know. I will keep that in mind with helping with my friends SS/SC.
Old 05-02-2007 | 01:31 PM
Area47's Avatar
Rent me! per hour
i had a car with over 400 ft lbs to the tire. {the gxp} yes i know all about traction issues. first gear is insanely short in these cars, hence why i have the boost limit.
the gxp on the other had, it had violent torque steer at 75-80 mph. to the point where i almost hit a friends supra because of the initial hit from the bottle
Old 05-02-2007 | 02:47 PM
MTchevy1's Avatar
Now YOU try my S10 with over 450lbs of torque on street tires, then you'll see traction problems in 3rd
Old 05-02-2007 | 02:53 PM
Cobalt_SSTuner's Avatar
or you can use a manual boost controler (or so i've heard) to control the maximum boost.
Old 05-02-2007 | 03:55 PM
NJHK's Avatar
It doesn't work as well as you think
Old 05-02-2007 | 03:56 PM
scottw03's Avatar
Not trying to start a torque war here LOL. At stock torque I didn't have as much of a traction problem. Now I do. Haven't been to the dyno since I installed the new turbo so I don't know where I stand with power at the moment. Should find out on June 9th.
Anyway back on topic. Boost controller, ok so you can't use a MBC to control boost like in an SRT-4 or WRX, STi, etc.... right?
Old 05-02-2007 | 03:58 PM
Admiral Jedi's Avatar
That's what I thought too, so I bought one. It can only disable boost completely or let it be 100%. It's adjustable, and I couldn't make it useful. My car is slow without boost.
Old 05-02-2007 | 03:59 PM
MISSMATCHEDFACES's Avatar
you can tie the boost controller into the wastegate.
Old 05-02-2007 | 04:04 PM
NJHK's Avatar
If you have a roots supercharger, you don't have a wastegate...
Old 05-02-2007 | 04:08 PM
boostbalt's Avatar
Lol this is funny, it's turned into a who's got more torque pissing contest. Hey let's start the who's got the biggest dick contest and who's got the most money contest too!
LMAO at the people who have "big torque", come on guys....
Old 05-02-2007 | 04:10 PM
the stock eaton has a wastegate
Old 05-02-2007 | 04:23 PM
That's where I put it, I tried flipping it around, it did nothing for me.
Old 05-02-2007 | 04:25 PM
Bryank930's Avatar
Wrong. Bypass valve. They do different things.
Old 05-02-2007 | 04:31 PM
NJHK's Avatar
Exactly.
Old 08-07-2007 | 07:26 PM
Boosted07SSSC's Avatar
Wait so on an all stock sssc how much can you safely run.
and will this actually increase performance?
Old 08-07-2007 | 09:02 PM
NJHK's Avatar
How much what can you run?
Old 08-07-2007 | 09:06 PM
Area47's Avatar
Rent me! per hour
cream filled cupcakes
Old 08-07-2007 | 09:24 PM
boost. how much boost.
on stock system
Last edited by Boosted07SSSC; 08-07-2007 at 09:24 PM. Reason: Automerged Doublepost
Old 08-07-2007 | 09:35 PM
Shanman's Avatar
85 lbs
Old 08-07-2007 | 09:37 PM
Blurred Vision's Avatar
a 2.5 pulley with a ported blower 60lbs injectors and a perfect tune u can run 23 to 24psi but u better invest in every cooling mod axels , and run drag radials cuz the stock tires wont catch traction till 3rd if ur lucky
Quick Reply: Boost Control
