brake setup opinion
Haz l33t wheelz.
CA Big Brake kit Offers everything you need for a inexpensive conversion. This kit is assembled using High Quality Wilwood brake Calipers. Kit is assembled with 12.8" front rotors with 4 piston Wilwood calipers . Rear kit offers 12.8" rear rotors with 4 piston Wilwood calipers. These kits come with stainless steel brake lines , machined caliper brackets , brake pads and all nuts and bolts for mounting . Clearance from outer hub to caliper is 1.5" for the front rim, so check rim fitment(may need spacers).May work with stock rims but will work with most 18" rims!! Rear kit eliminates the parking brake currently.
Front Kit in Stock , Rear special order 4 weeks
CA FRONT Big brake kit : Your Price: $699.99 USD + $39.99 Shipping
CA REAR Big brake KIT : Your Price: $799.99 USD + $39.99 Shipping
Haz l33t wheelz.
For similar dollars, the OEM front brembo upgrade is 100% superior to the Wilwood aftermarket set up. I like Willwood I use their 570 brake fluid for race applications its an excellent product well priced. But you will find it difficult to beat the quality of the OEM Brembo brake components....
yeah i know but i was thinking a little different path. Everyone seems to be jumping on the brembo bandwagon and i was just thinking outside the box.
I understand where you are coming from, but sometimes, inside the box is better. and how many folks have actually upgraded? and you can powdercoat if you want to stand out from the crowd and add floating rotors like I did... last thing, what carries more feng shui? Brembo or Wilwood? lol
Haz l33t wheelz.
I want your rotors. Not that i need them, i like bling.
p.s. where can i get some of those nifty rubber bleeder covers? My bleeder screws are rusting like gangbusters. Will the dealer have them?
Just a minute...
YOU GET RUST IN CALIFORNICATION????????
Haz l33t wheelz.
that wonderful sea breeze. Things actually rust very easily here, i wash my vehicles at least once a week to keep the salt off. It's kinda ridiculous.
I still have a variety of setups available for both the SS and na cars. Have not posted much here in quite some time as the shop's been busy with other platforms and sadly this one has not been terribly busy. Not sure totally why but I'm sure the economy has something to do with it and the simple fact is that $1200-1500 remains costly for a lot of folks.
Altered the product line a bit also of late and don't see any further expansion on this one right now. Custom work is always an option of course.
