build tally's
Old 06-17-2007 | 10:48 PM
sunfirejoe's Avatar
build tally's
hey guys i wanna know when u blew your motor, or changed pistons whats ur tally
im kinda curious, if u wanna lay our price breakdown or just a total cool, im just going through mine
dont include injectors and pulleys, unless u blew your motor and added them all during the build
if ur build also includes labour please make sure to seperate it, unless its like balancing of machining
ill post mine currently once i get my tallied up
Old 06-17-2007 | 10:54 PM
06noscobaltss's Avatar
Most mods in signiture minus the pulley injectors and exhaust were done in this build
FIRST BUILD:
Parts costs- $8600
Labor- $3900
Cracked the block. Second build going different route
$7k parts and labor
Old 06-17-2007 | 10:58 PM
ptrblkz24's Avatar
FIRST BUILD:
Parts costs- $8600
Labor- $3900
$7k parts and labor
You have any pics of your blower delete kit?Where did you get it from?Im looking for a kit so i can remove my s/c.
Old 06-17-2007 | 11:11 PM
No pics as it is being developed at this time by an unnamed company at this time. Details will be released soon!
Old 06-17-2007 | 11:23 PM
ptrblkz24's Avatar
oh,ok.
Old 06-18-2007 | 12:17 AM
syP's Avatar
syP
ooh ooh.. i know
shhhh
Old 06-18-2007 | 02:42 AM
sunfirejoe's Avatar
cam timing gears - 315
balnce delete kit - 210
main studs - 116
pistons - 565
rings - 140
balancing - 300
sleeve - 160
misc bearings and bolts - 160
head agsket and studs - 285
build tally in canadian funds is 2250 cnd,
kinda crazy but still under my budget, i have a new head and head work done, but that wont be until later in the summer, i still have to have all my valves and springs installed(need to be purchased as well), i just cant not drive this car anymore
soon ill be running, ill get vids up soon
Old 06-18-2007 | 02:44 AM
SilverBalt13's Avatar
Where did you get the piston rings from? Are you going to just a new set of stockers?
Old 06-18-2007 | 02:47 AM
sunfirejoe's Avatar
no i went through intense cuz i was tired of waiting, but call total seal and ask for part number 09143385 its a 3.385 Bore file fit, also another number on the box is CR8674 40
1.2MM Moly Ductile Compression Ring
1.5 RBT- cast Iron 2nd ring
3.0 MM Low tension Oil ring
Old 06-18-2007 | 02:49 AM
Ya im getting tired of waiting also. I have talked to people and they said the stock rings can hold at least 400 hp. Does anyone know this for sure.
Old 06-18-2007 | 02:55 AM
sunfirejoe's Avatar
they should be ok, i replaced mine b/c i blew a ring land, if ur going full out id replace them, calling total seal will probably cost u less, but cnd phone calls cant get through
Old 06-18-2007 | 02:56 AM
Do you have a phone number for them? If you do can you Pm it to me.
05-28-2022 03:47 AM
ineedacobaltss
11-07-2015 02:25 PM
hacadacalopolis
10-28-2015 06:09 PM
patooyee
10-15-2015 05:11 PM
09-26-2015 06:44 PM
Quick Reply: build tally's
