Bwoody vs TTR vs CA
Bwoody vs TTR vs CA
Originally on my cobalt I had a TTR motor mount, and CA trans mounts. This combination worked beautifully on the cobalt. I sold everything to get thru a jam, and now am in the process of building up slowly as it comes. I just noticed tho that I can get a full set of solid mounts for the balt from Bwoody for 260 bucks, vs 160 for TTR mount and then whatever CA costs. Thats not really what im thinking tho, im trying to find out if anyone has used the Bwoody setup in their balt and what were your thoughts, I know TTRs mount looks a HELL of a lot beefier. But I really havnt heard anything bad about bwoody on other parts.
Any and all feedback is appreciated. thanks
my_bd with his TVs in the redline has the b-woody ones i believe..they're basically solid metal with a bushing at the top for the side engine mount haha his are like no movement at all..if i think you are talking the ones im thinking about
I get into it with the RL guys all the time about the Bwoody Mounts VS the ZZP and TTR mounts. Its pretty easy to see that the ZZP and TTR Mounts are far superior in design over the Bwoody ones...
Bwoody
TTR and ZZP
The bwoody mounts are basically Motor mounts wrapped around tubes. You can actually see the engineering work that went into the ZZP and TTR mounts.
That was my setup and I had zero wheel hop.
Spam alert! lol I am selling my ZZP lower Trans mounts.
https://www.cobaltss.net/forums/parts-66/fs-ttr-top-engine-mount-zzp-lower-trans-mounts-not-bwoody-140306/
You won't find a better deal on the intraweb.
Bwoody
TTR and ZZP
lol you have the exact setup I had. TTR and ZZP. by the way i pmed you on the ZZP mounts... I LOVED that set up. Your right, so much more engineering is quite apparent.
TurboTechRacing
10-27-2015 07:58 AM
