CA Heat Exchanger
CA Heat Exchanger
I bought a used Cobalt Addiction heat exchanger off someone from this site. They didnt give me any instructions soo some one who has one can you please tell me how u install it?? It came installed with the bracket and the 2 steel braided hoses.
Yeah i already read that but the brackets are at a different place and the CA heat exchanger has a bleeder screw....
Anyone???
Anyone???
Last edited by SS/SC05/19/05; 03-04-2007 at 10:45 AM. Reason: Automerged Doublepost
I too called Cobalt Addicition and they told me to do a search here to find ideas since they don't have any instructions.
You don't have to take off the bumper to do the install, but it makes everything a little easier. I spent about three hours installing this...and I had to do a little modifications to the bracket (extended the length)......so that it was pefectly centered and there was enough clearance that you won't break the petcock off.
I did remove the stock heat exchanger...which is between the a/c condensor and radiator.
HOPE THIS HELPS and GOOD LUCK!
Here are some images to give you an idea.
From the side
From the side
From the front
From the top
From the side
From the side
From the front
From the top
does it work with your stock heat exchanger or you eliminate your stock one?
I jsut got a cobra one and Im worndering whithc lines I hook it up you and waether it works with the stock h/e or you don use that anymore
and if you dont use it anymore how hard is it to remove the stock h/e?
and how about after i install it?? Do i need to bleed the system and how would i do that?? Also do i need to add even more coolant also?? Sorry for all the questions but i just dont wanna **** up my car..
oh one more question, mine doesnt have anything on the end of the hoses so what did you use?? A hose clamp or am i missing something??
Last edited by SS/SC05/19/05; 03-17-2007 at 11:44 AM. Reason: Automerged Doublepost
hoe clamps to the pump and res... it's an AN fitting to the H/E,.
and the worst part about the install is bleeding the system... just takes awhile.
also I recommend used redline water wetter, or royal purple "purple ice" to further increase cooling capacity along with topping it off with a 50/50 mix of dexcool and water
i just installed the heat exchanger this morning. I left the bumper on and it took me 4 hours!!! The stock outlet hose was a bitch to get off!!![IMG]C:\WINDOWS\Administrator\My Documents\My Pictures\phone pics 4[/IMG]
sorry i cant figure out how to put a picture on there just check my vb garage
Last edited by SS/SC05/19/05; 03-31-2007 at 09:31 PM. Reason: Automerged Doublepost
n20saturn
09-30-2015 12:26 AM
