CA V1 header.
Old 02-04-2010, 11:06 AM
roboticfister's Avatar
I'm running a Weapon R with a custom 3" collector/DP... the main reason I went with it is the 2 to 1 piping on each set of cylinders ending up with two separate outlets to manufacture a collector out of. I sold off the dp that came with it to recoup some of my cost for the header (which is way expensive) but I think I ended up with about the best exhaust flow after all was said and done that I could. It also opens me up to run dual catless side pipes if I should ever choose and have a true 2 to one on both sides of the car. But that's for when I'm done with it as a daily driver and build the engine
Old 02-04-2010, 06:52 PM
Flatgod's Avatar
Leaking coolant?
Old 02-04-2010, 07:46 PM
advise's Avatar
for the v1 header the coolant pipe has to be rotated if not the header pushes on the pipe making it leak
Old 02-04-2010, 09:26 PM
chevysssc's Avatar
like stated lot more mid-high end hp very noticible
Old 02-04-2010, 10:35 PM
Caligula's Avatar
Can someone tell me what gasket I need to buy for this header?
Nevermind. Found it.
Old 02-04-2010, 11:45 PM
utibalt's Avatar
alright kool so i can just rotate the coolant pipe and it should be fine? any special way to rotate it? i've been driving on it for only a day now, doesn't seem like it's leaking the coolant, but it is still pretty close to the pipe..
Flatgod's Avatar
IC didn't know that.
Old 02-05-2010, 12:05 AM
advise's Avatar
https://www.cobaltss.net/forums/show...nt+pipe&page=3
check post #43 it explains
Old 02-05-2010, 12:42 AM
utibalt's Avatar
alright kool, i'll try and take care of it tomorrow at work..
Old 02-05-2010, 01:05 AM
scotch89's Avatar
does the v2 header bolt on the stock downpipe? i have 07 ion redline
Old 02-05-2010, 01:08 AM
  #36
advise's Avatar
yup
Old 02-05-2010, 01:46 AM
  #37
YzRider452's Avatar
Why would u run a header with a stock dp?
Blown 4-banger
07-06-2007 02:07 PM
YellowLT
05-23-2007 07:10 PM
ICEMAN187
05-11-2007 12:14 AM
RED COBALT SS
04-23-2007 09:01 AM
kenhebe
02-04-2007 03:42 PM
Quick Reply: CA V1 header.
