CAI install walk through
try a search in the how to section?
https://www.cobaltss.net/forums/sear...archid=5162856
...that was hard.....
dont know of a walk threw but its simple man listen.
1pop the hood and disconnect the stocker from the throttle body
2jack the car up and pull the drivers side wheel off
3then take out all the little bolts on the front side of the wheel well theres some underneth that are screwed into the front bumper i think theres 7 of them maybe 8 then just fole the fender well over the rotor to get it outta your way
4 unplug the maf sensor from the stock intake
5 unbolt the rest of the bolts that hold the stock intake on
6 take out the maf sensor and install in in CAI intake
7 bolt in CAI attach throttle body put screws back in fender well put tire back on
8 enjoy the great supercharger whine
also, i provided more help then you did. why not answer peoples question instead of taking things off topic.
I should have no problems with my background in cars, I just wanted to see how many sensors their were and how they plugged into the tube. The way the air filter is tucked into the bumper it's hard to see anything without taking stuff apart.
one thing thats not on the write up. If you take out the driver's side head light...it makes it much easier.
