cam angle sensor
its there so the pcm knows were the cams are. this is needed for the pcm to know if the motors firing cyl 1&3 or 4&2 during the next rotation of the crank. when the cam sensor has issues the pcm will default to waste spark ignition, firing all 4 coils during each rotation of the crank, so when the exhaust valve is open, the coil in that cyl wil fire.
I'll make this really simple.
Set the #4 piston at TDC. Then on the housing of where the cam sensor is, you will see a small line/engraving. Line that up with the key on the sensor and put it together.
