can u say pauls turbo 2.0
#451
If he does release it, it's gonna be setup exactly like my car, external wastegate with dump, blow through maf setup. As for turbo options, I don't think he's going to order an upgrade, as getting this one to fit properly was a big enough pain in the ass. but I will talk to him next friday and see what he says
#452
I was just going to do a custom setup with a GT28 but, after looking at Rebel's Group Buy price, it actually isn't that bad of a deal. Especially if their new custom exhaust manifold works out, that thing looks very nice.
But if CA can get a better price with a close setup, I would be there.
#456
I don't know about the pistons, but the rods are no problem. You could probably talk to Diamond and have them make you a set of LSJ pistons with the 21mm wrist pin. Since they already make the LSJ pistons, I don't see why they couldn't make one with the smaller wrist pin without too much, if any extra charges.
#458
They should be the same bore according to the GM Spec sheets. Talk to Diamond, they make pistons for both. They would know best.
#460
#461
what was there prices at? and what are they at now? im hoping kenny releases this kit just cause i'd really like to see a well put together turbo kit at a reasonable price
#462
he hasn't pm'd me back with the new ones yet, based on the thread i'd imagine 500 more on each stage.
#471
Turbo Boost > Supercharger Boost
Dans car @ 15lbs was definitely quicker than mine now.
Quick question, what did you do to the SCIP Sensor that is usually on top of the blower? Just ignore it?
#472
I just disconneted it and shut off the cel code.
I'm gonna try planing with PE today to see if thats why the car is dumping fuel. Just realized I still have it set to come in a 2500 rpm from the s/c tune. That might be a factor since I'm only at like 3 psi vs 15-17 with the s/c. I'll delay to 3500 or 4000 or so and see what happens. hopefully it works cause I want to dyno on the 21st, and may run it this sunday at e-town if I can get it running right.
#473
I was planning on using the same turbo t3/t4 57 trim, because i can get one through a friend for hella cheap new. I'm only looking to run 15-16lbs of boost. How much do you think the stock internals can handle?
