can u say pauls turbo 2.0
Old 10-07-2007, 12:31 PM
  #451
06blackg85ss's Avatar
If he does release it, it's gonna be setup exactly like my car, external wastegate with dump, blow through maf setup. As for turbo options, I don't think he's going to order an upgrade, as getting this one to fit properly was a big enough pain in the ass. but I will talk to him next friday and see what he says
Old 10-07-2007, 12:36 PM
  #452
WSFrazier's Avatar
I was just going to do a custom setup with a GT28 but, after looking at Rebel's Group Buy price, it actually isn't that bad of a deal. Especially if their new custom exhaust manifold works out, that thing looks very nice.
But if CA can get a better price with a close setup, I would be there.
Old 10-07-2007, 12:59 PM
  #453
I'll be hitting the dyno in 2 weeks so we shall see what kinda numbers this setup makes
Old 10-07-2007, 03:27 PM
  #454
braddddddd991's Avatar
do you have any vids at wot yet?
Old 10-07-2007, 04:17 PM
  #455
not yet. Vid camera is still acting up. Hopefully next week sometime. Don't really have any time lately
Old 10-07-2007, 07:11 PM
  #456
Cobalt_Supercharged's Avatar
I don't know about the pistons, but the rods are no problem. You could probably talk to Diamond and have them make you a set of LSJ pistons with the 21mm wrist pin. Since they already make the LSJ pistons, I don't see why they couldn't make one with the smaller wrist pin without too much, if any extra charges.
Old 10-07-2007, 07:18 PM
  #457
good idea man. I'll see about that, But wouldn't the 2.2 pistons be the same bore and whatnot? cause if they do work, I"ll probably be buying those in a week or two and getting my motor finally assembled
Old 10-07-2007, 07:23 PM
  #458
They should be the same bore according to the GM Spec sheets. Talk to Diamond, they make pistons for both. They would know best.
Old 10-07-2007, 07:27 PM
  #459
will do
Old 10-07-2007, 07:52 PM
  #460
jimbos'ss's Avatar
i've decided i'm going with the rebel kit as well, bear in mind the group buy prices are over now.
Old 10-07-2007, 08:33 PM
  #461
skymynx's Avatar
what was there prices at? and what are they at now? im hoping kenny releases this kit just cause i'd really like to see a well put together turbo kit at a reasonable price
Old 10-07-2007, 08:40 PM
  #462
jimbos'ss's Avatar
the old prices are in this thread:https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/rebel-auto-worxs-turbo-kit-group-buy-72861/
he hasn't pm'd me back with the new ones yet, based on the thread i'd imagine 500 more on each stage.
Old 10-07-2007, 09:40 PM
  #463
skymynx's Avatar
personally i've meet kenny and a few of the guys from CA. i'd much rather deal with them. well have to wait and see.
Old 10-07-2007, 09:54 PM
  #464
Vip09's Avatar
Can't wait to see what happens with the new engine. It's going to be a beast.
Old 10-08-2007, 11:53 AM
  #465
Cobalt_SSTuner's Avatar
So i was searching through the thread, but couldnt find it, what exactly was wrong with the maf sensor?
Old 10-08-2007, 12:02 PM
  #466
the piping is too small (2.5") need it to be 3", increased velocity is pegging the sensor out almost immediatly
Old 10-08-2007, 12:05 PM
  #467
ah, ok i gotcha, and and ur running a t3/t4 tubo?
Old 10-08-2007, 12:07 PM
  #468
apparently
Old 10-08-2007, 12:10 PM
  #469
and how is the lag?
Old 10-08-2007, 12:12 PM
  #470
not too bad, full spool by @4000 rpm, making @7-10 psi at 3k and so on. but once that thing hits it's all over. (on 14 psi and low timing it was already faster than my s/c setup on 21psi)
Old 10-08-2007, 12:14 PM
  #471
WSFrazier's Avatar
Turbo Boost > Supercharger Boost
Dans car @ 15lbs was definitely quicker than mine now.
Quick question, what did you do to the SCIP Sensor that is usually on top of the blower? Just ignore it?
Old 10-08-2007, 12:18 PM
  #472
I just disconneted it and shut off the cel code.
I'm gonna try planing with PE today to see if thats why the car is dumping fuel. Just realized I still have it set to come in a 2500 rpm from the s/c tune. That might be a factor since I'm only at like 3 psi vs 15-17 with the s/c. I'll delay to 3500 or 4000 or so and see what happens. hopefully it works cause I want to dyno on the 21st, and may run it this sunday at e-town if I can get it running right.
Old 10-08-2007, 12:20 PM
  #473
I was planning on using the same turbo t3/t4 57 trim, because i can get one through a friend for hella cheap new. I'm only looking to run 15-16lbs of boost. How much do you think the stock internals can handle?
Old 10-08-2007, 12:30 PM
  #474
well I've been running 18psi with no issues cept for to much fuel. I'm gonna try running around 21-23 psi with meth and see what happens
Old 10-08-2007, 12:35 PM
  #475
cool, what do you think about having the turbo mouned off the downpipe instead of a turbo manifold?
Quick Reply: can u say pauls turbo 2.0
