can u say pauls turbo 2.0
Old 10-08-2007, 12:37 PM
  #476
06blackg85ss's Avatar
hey if you can get it to work, It'll probably be easier to mount there than were I got mine, room is at a premium.
Old 10-08-2007, 12:44 PM
  #477
Cobalt_SSTuner's Avatar
thats what i was thinking. I was just hoping it wouldnt hurt flow, causing boosting issues.
  #478
Rattlesnake Race Shop
USMCFieldMP's Avatar
You just need to make a long tube Turbo Manifold... that would be best... most that I have seen are rather short... or normal length.
Being further back will help out because the longer piping helps to cool the charge.
Old 10-08-2007, 12:47 PM
  #479
very true
Old 10-08-2007, 12:52 PM
  #480
also being sandwiched btwn the motor and the firewall isnt' the greatest place for it (like 1/2" of clearence on both sides) I didn't even have room to run piping for the filter, just had to mount it right to the turbo.
If I do decide to run the 60-1 on this car in a few months, I'll probably redesign some things for a new manifold cause I know it ain't gonna fit back there.
Old 10-08-2007, 12:58 PM
  #481
yea there isnt a whole lot of room back there
Old 10-08-2007, 01:21 PM
  #482
djt81185's Avatar
Wes...I just left the scip sensor there and did nothing to it or its codes. Its there for throttle response iirc
Old 10-08-2007, 01:24 PM
  #483
WSFrazier's Avatar
Yeah, but I don't plan on just gutting the blower like you did and leaving it there. Some SOB will pay money for it
Old 10-08-2007, 03:17 PM
  #484
intense_SS's Avatar
BUMP for more of those sick vids!!
Old 10-08-2007, 03:25 PM
  #485
Edubs's Avatar
Fo' Shizzle...
Old 10-08-2007, 03:41 PM
  #486
my nizzel
Old 10-08-2007, 04:06 PM
  #487
Rent me! per hour
Area47's Avatar
drop the timing down, and leave the pe entry where it's at. it will spool faster. might want to stick an egt in there to monitor the temps pre-spool and post. just trying to see the car be on the safe side
Old 10-08-2007, 04:46 PM
  #488
WSFrazier's Avatar
Yes, that anti-lag FTW, but damn on the EGT side.
Old 10-08-2007, 04:58 PM
  #489
actually dropping the timing made it a bit worse. I'm goin to play with it a little this week and see what happens. Car's weird though, sometimes it'll make a full pull, afr will stay right where I wanted it to and all is good, other times it just drops below a 10 afr and bogs.
As for the scip sensor, is it really necessary to run it? if so I gotta figure out a way to mount it in the piping
Old 10-08-2007, 05:04 PM
  #490
WSFrazier's Avatar
Best bet would be to either get a hold of WOP about the SCIP or PM Witt/DJT.
Old 10-08-2007, 05:05 PM
  #491
good idea. That could be what screwing with my fueling. I"ll give em a try..... or just wait for one of em to pop back in the thread lol
Old 10-08-2007, 05:08 PM
  #492
WSFrazier's Avatar
Good luck getting a hold of Al. He pretty much only uses the internet for WoW now.
Old 10-08-2007, 05:09 PM
  #493
so I've heard
Old 10-08-2007, 08:56 PM
  #494
Cobalt_Supercharged's Avatar
I say do an STS remote mount turbo. Plenty of room.
Old 10-09-2007, 10:26 AM
  #495
mezzanno's Avatar
Originally Posted by 06blackg85ss
so I've heard
get his wow name and find out what realm he's on. I have a wow account, Ill make a character for you so you can get through to him if you want
Old 10-09-2007, 10:53 AM
  #496
Rent me! per hour
Area47's Avatar
oh thats sad
think of the you timing like this. the big name drag people with turbos run negative timing till about the 330 mark. gear based advance/retard. fuel is being dumped at a retarded rate as well. heat is built, turbo is spooled. car is gone. is this effective? yep, but not for a street car.
Old 10-09-2007, 11:00 AM
  #497
I'll play around with it some more this weekend, had to tune my friends 07 silverado last night, so didn't really get a chance to mess with mine.
Old 10-09-2007, 11:14 AM
  #498
1gmfanatik's Avatar
How accurate do you think the Interceptor is for posting up quarter mile times?? I did a quick pull last night and came up with some GOOD numbers
Old 10-09-2007, 11:27 AM
  #499
Darksun's Avatar
no......
Old 10-09-2007, 11:29 AM
  #500
if you do a huge burnout not accurate, if you do it with zero tire spin, then your numbers could be somewhat close.
Quick Reply: can u say pauls turbo 2.0
