can u say pauls turbo 2.0
Old 10-15-2007, 12:24 PM
  #651
06blackg85ss's Avatar
**** man, sorry to hear that. Anything in particular that caused it? or just too much boost. I'm trying to see how long my stock motor lasts, but I have a set of forged rods on the way, another block, crank, forged pistons, ARP main studs, head studs, nuetral balance shafts, and some other goodies sitting in the shop just waiting to be assembled when the stock motor eventually lets go
Old 10-15-2007, 12:30 PM
  #652
Cobalt_SSTuner's Avatar
aw man, i'm sorry to hear that
Old 10-15-2007, 12:39 PM
  #653
SSdan's Avatar
Ouch.
Old 10-15-2007, 12:40 PM
  #654
WSFrazier's Avatar
There is no way you over powered the rods. Most likely something with the bearing. Either put in crooked/wrong or rod caps were too tight/loose.
Old 10-15-2007, 12:41 PM
  #655
djt81185's Avatar
Im thinking it might have been when we put the rod bearings back in...I wont know until I get a better look. I think it was definately build related and not too much boost or anything
Old 10-15-2007, 12:43 PM
  #656
skymynx's Avatar
oh damn good luck trying to fix it.
Old 10-15-2007, 12:44 PM
  #657
damn,, hopefully it didn't tear up everything up too bad.
Old 10-15-2007, 12:46 PM
  #658
WSFrazier's Avatar
Salvage out those neutrals, maybe even pistons. We can just JB Weld the block, patch her up.
Old 10-15-2007, 12:47 PM
  #659
I think I'm just gonna send my motor out to a professional for assembly, never done an ecotec before only sbc's. don't want to break some expensive parts
Old 10-15-2007, 12:54 PM
  #660
WSFrazier's Avatar
My car and Al's car run find, and I beat the **** out of mine. Al takes his past 8k when possible. Hopefully Dan finds out what caused this.
Old 10-15-2007, 01:37 PM
  #661
Rent me! per hour
Area47's Avatar
i want 8k
Old 10-15-2007, 03:56 PM
  #662
I just can't wait to get the damn motor finished. Been waiting on rods for a while now, finally found a set and they should be on the way. Once they are in, I"ll order the new bearings, and probably the Bates oil pump gear, send out the cams, have my friend clean up the head. and it's gonna be fun times
Old 10-15-2007, 04:02 PM
  #663
Smarty Art's Avatar
Wes and Als car is fine cause they aren't running an insane amount of boost.
Old 10-15-2007, 04:04 PM
  #664
Rent me! per hour
Area47's Avatar
so. a 2.5 pulley doesn't make an insane amount of boost?
Old 10-15-2007, 04:05 PM
  #665
Smarty Art's Avatar
A 2.5 pulley doesn't make 30lbs of boost, but I don't know what he was running at the time of destruction.
Old 10-15-2007, 04:08 PM
  #666
WSFrazier's Avatar
Dan was running the normal 20lbs. Thats why I say he wasn't overpowering anything in the motor. It was a flaw in the build most likely. If Dan tears her open tonight, we shall know.
Given, he said he was doing a 140+ run and was holding a sustained high RPM, but it shouldn't be anything the motor couldn't handle.
  #667
30lb's goddamn man, I wasn't planning on going past 25 psi with this turbo or the bigger one I'm putting in after the build
Old 10-15-2007, 04:14 PM
  #668
Rent me! per hour
Area47's Avatar
the fun begins when the boost gauge reads above 25.
Old 10-15-2007, 04:15 PM
  #669
22 is good right now
Old 10-15-2007, 04:22 PM
  #670
i wanna it 15-18lbs with a turbo thats good enough for me lol. I can always up it and retune if i need to. I'm buying piping tomorrow, am i better off with 3" or 2.5"?
Old 10-15-2007, 04:27 PM
  #671
djt81185's Avatar
I just put it up on jackstands...whatever it was it happened on the front of the motor. Near the passenger side, above the oil pan, below the intake manifold. Thats all I can see right now...and afaik there isnt anything that runs oil thru there. Least externally and can leak.
Old 10-15-2007, 04:30 PM
  #672
not to my knowledge either man, probably snapped a rod, hopefully it didn't take out everything else like they usually do on ecotecs
Old 10-15-2007, 04:32 PM
  #673
WSFrazier's Avatar
Either #1 rod, or something with the neutrals, in the timing area. I put the bearings in, and you tightened/TQ'd them. I know the bearings were perfect. Like everything I do
Old 10-15-2007, 04:33 PM
  #674
djt81185's Avatar
Originally Posted by lsjwannabe
exactly but see im a lazy guy so thats why i don't get to much into detail
Thanks for the negative rep that reads...******* tool. It was posted 1 minute after you made this post.
Next time have the ***** to leave your name next to it
If its not you I apologize but after seeing the other stuff in the gt500 thread it l have reason to assume its you
Old 10-15-2007, 04:34 PM
  #675
true, maybe the gear came off and chain was smacking around in there and made a hole
goddamn man, why the **** would someone do that?
Last edited by 06blackg85ss; 10-15-2007 at 04:34 PM. Reason: Automerged Doublepost
Quick Reply: can u say pauls turbo 2.0
