can u say pauls turbo 2.0
Old 10-24-2007, 09:55 AM
  #851
Darksun's Avatar
Originally Posted by 06blackg85ss
Yeah, I laughed at that one. considering at 16 psi and 1/2 throttle I blew the doors off a 2.7 pullied cobalt that I had tuned
Which fool said that? I'll handle him for ya with my 225 whp
Old 10-24-2007, 10:03 AM
  #852
Rangerondubz's Avatar
Baby Jesus
Old 10-24-2007, 10:55 AM
  #853
Rent me! per hour
Area47's Avatar
four cars are doing the same thing. completely different set ups. same issue on the fuel. something in the fuel tables themselves?
so ya got the throttle body eh?
Old 10-24-2007, 12:13 PM
  #854
06blackg85ss's Avatar
yeah didn't get a chance to install it yesterday, if it stops raining I'll do it tonight.
Having a bad idle issue though, car leans out completely at idle... like ---- out the gauge. But overall driveability is much improved. doesn't have hesitation anymore. did some work on the VE tables today at work, gonna test that out on the way home from work tonight and see how it works out.
Old 10-24-2007, 12:23 PM
  #855
Rent me! per hour
Area47's Avatar
right on. have fun with it! i have already retuned one car here in town that did the tb mod.
my idle afr does weird stuff every now and then. it wants to run at 21.8 afr. sounds cool {sounds like witts car} but the egt starts to climb fast. then it drops down to the 14 range and the egt drops.
weird wild stuff i tell ya
Old 10-24-2007, 12:25 PM
  #856
yeah but my TPS% changes all over the place at idle too which it really shouldn't do. I dunno car is acting weird again. We shall see what happens in a few when I reflash it again for @ th3 500th time
Old 10-24-2007, 12:46 PM
  #857
Rent me! per hour
Area47's Avatar
thought about doing a full rewrite instead of a flash?
Old 10-24-2007, 12:55 PM
  #858
well just reflashed it again at lunch, idle is much better etc% stays btwn 5-7... but my o2 voltage is doing some wierd ****.... and this is my 5th set of 02's on the car (leaded race gas this summer lol) AFR's stay btwn 13.8 and 15.5 (mostly 14.6-14.8) which is better then before. I'll see how it drives now tonight.
Old 10-24-2007, 01:06 PM
  #859
Rent me! per hour
Area47's Avatar
i redid my pe table this morning to comp for the 2.7 i put on it last night, and the drop in temps.
my car hates me, my tires scream in agony, and i giggle like a little school girl.
blower, turbo. it's a never ending battle
Old 10-24-2007, 01:37 PM
  #860
Cobalt_SSTuner's Avatar
thats going in my sig lol
so it sounds like (for the most part) the major issues are gone?
Last edited by Cobalt_SSTuner; 10-24-2007 at 01:37 PM. Reason: Automerged Doublepost
Old 10-24-2007, 03:23 PM
  #861
Witt's Avatar
Check for an exhaust leak between the head and where your primary o2 is located if you are throwing any type of fuel trim codes. If you aren't throwing a trim code, check between the primary o2 and where your wideband o2 is mounted.
I had a bouncing ETC when I first recammed and it was because the idle was too low and not pushing enough air past it fast enough. Dan had the same issues as well and an increased idle fixed the problem. If you have an increased diameter pipe than stock where your primary o2 is housed you might not be pushing air at a fast enough speed required for the o2 to sweep 14.7 at idle at a fast enough speed. Sometimes you'll throw an insufficient o2 switching code for it but its sporadic.
Old 10-24-2007, 03:40 PM
  #862
I do have a bad leak right now, lost a bolt on the turbo manifold head to the flange.... That could be it. well it stopped raining finally, time to put in the new tb and let her rip.
Old 10-24-2007, 04:17 PM
  #863
Rent me! per hour
Area47's Avatar
have fun with the tb
i think a lot of you issues stem from a boost leak somewhere.
p.s. sent you something to play with.
Old 10-24-2007, 04:24 PM
  #864
good ****. I'll check it out when I get back to me casa...
you get the pulley and hub?
but yeah I found a few spots, one I'm missing one of the backplate clamps on the turbo that hold the compressor housing on... don't know where the hell that went lol. got one from another turbo I had layin around so fix that tonight if it doesn't rain anymore. But I went over all the t-bolt clamps and couplers and nothing looks out of place.. so it's either the turbo leaking, or the maf adapter which pooped out a gasket.
I got some work ahead of me tonight
Old 10-24-2007, 04:39 PM
  #865
Rent me! per hour
Area47's Avatar
i haven't been home yet so probably. i checked it this morning said it was "out for delivery" so at some point i will get it. i have a 2.7 on the car right now i got monday. holy crap! now i see why you went turbo. this is addicting.
everything cool with the tb and couplers?
Old 10-24-2007, 04:44 PM
  #866
everything looks cool... hopefully get em in this morning
Old 10-24-2007, 04:50 PM
  #867
Rent me! per hour
Area47's Avatar
i think you're confused batman
Old 10-24-2007, 04:52 PM
  #868
Evening lol... busy at work... 20 things at once deal lol
Old 10-24-2007, 04:55 PM
  #869
Rent me! per hour
Area47's Avatar
wow, and i thought i was fried!
i just checked the ups deal this morning, yours is delivered, and mines stuck on a truck
Old 10-24-2007, 06:03 PM
  #870
lol yeah I got it yesterday... just hoping this damn drizzle stops. Also the car is driving a 100% better now, throttle response, and low speeds are excellent with my new maf tuning.
Only thing is now my afrs just drop to 10.0-10.4:1 if I punch it. but from what I can tell it seems to be holding steady all the way up. I'm shooting over to my friends house tonight to see if I can fix his s/c. Hopefully get a full 3rd gear pull in somewhere on the highway going out there. Maybe wait til then to toss in the tb too
Old 10-24-2007, 06:33 PM
  #871
Greased's Avatar
wow i saw those dyno numbers practically shat myself, thats beautiful dude i got a little turbo envy right now
Old 10-24-2007, 07:02 PM
  #872
lol thanks man..... those numbers are only gonna go up... Doing something new with the car very soon and pretty much changing the whole setup in the next few weeks.....
Old 10-24-2007, 07:44 PM
  #873
2K5SS/SC?'s Avatar
Paul, boost leak test and get all those exhaust leaks fixed. Trust me, it makes all the differences in the world. My buddies WRX was being a pain like this. We boost leak tested his car and found a ton of leaks. Went from 19psi-21psi after fixing the leaks alone! The car also finally idled nicely and pulled smooth again. As far as the A/F ratios go, if you have the MAF finally tuned right, now you'll definitely need to go back and adjust your PE tables.
Isn't all this stuff fun? Make one change and everything else goes to hell in a hand basket! I know I sure look at it as a love/hate relationship! :lo:
Old 10-24-2007, 08:02 PM
  #874
lol yeah I'm kinda used to this stuff now, just the problem is with all the other customer cars I work on I never have time for my own. Last night was the first chance I had to do any real tuning on my car, on the dyno, it was still basically tuned for the s/c lol. Not bad for that right. But yeah, tomorrow is new TB day and redoing my PE setup. It's wierd though, car is going under commanded afr.... Used to sit a little leaner than commanded now it's almost a full point richer if not more in some places. I have it set at an 11.4 afr. I'll see what leaning it out a bit tomorrow does
Old 10-24-2007, 09:05 PM
  #875
Cobalt_Supercharged's Avatar
here's a different view of log #3
blowthrough maf setup
It's funny seeing IAT1 so much higher than IAT2.
Quick Reply: can u say pauls turbo 2.0
