Can't get rid of CEL
I can't get rid of my CEL and it's pissin me off....I'm getting a code saying my car is running lean...I have replace both o2 sensors and cleared the code and it keeps comming back on...Only thing that is done to the car is a Vibrant header,Vibrant catted dp and vibrant 3'' exhaust... I have a new wideband and my car is running 14's at idle and while driving it's staying in the 14's-and low 15's while driving.....any suggestions
exhaust leak, if you have a leak at the header, could be letting air into the exhaust causing the code. Id check for an exhaust leak before the cat and about a foot after the downstream 02 sensor
as far as i know it's stock...i just had this motor put in like a month or 2 ago and it had a CEL when we first started it up....im also having problems with my inside lights dimming...i just replace the battery and had the alt check and they said the alt was good...nothing but ******* problems....lol
The full exhaust on your car might have caused the fuel trims to go out of whack. I would guess you would know if you had an exhaust leak, so Im going to say get ahold of someone who can take a look at your tune and see if they can fix it or if thats what it is. To get the 0171/0172 (<--those are a guess out of my memory) dont your fuel trims need to be off by a lot, like 20%?
