Car won't start after TVS install
It comes with a base tune man u need to fine tune it its just so the car runs and moves..you need it tuneed. On there website it says it comes with a base tune that u need to tweak yourself
it turns over? it doesnt jus go "click" with the security lock on? I would go over everything you plugged in especially make sure you plugged the pcm back in properly.
Your car has to run to do a case relearn. That's not the problem here.
Well, I hooked my Stage 2 back up, and it runs perfectly. So I'm thinking, its either in the tune or the new injectors. I know its not any of the sensors now. What a disappointment. I knew I hooked everything up correctly.
On a side note, when I took the new injectors back off, the far injector exploded in my face and I got gas in my eyes. Good way to start off the day, ahaha.
No, the injectors came with the harness. I contacted Sean and explained what was going on, and he told me to send back the PCM so he could check it for errors. Hopefully this fixes the issue because I have no idea what else it might be.
Getaway_Driver
40
09-10-2015 09:11 AM
RedLined
09-09-2015 09:11 PM
Getaway_Driver
09-08-2015 09:41 AM
