cat back exhaust
cat back exhaust
I just swapped to turbo and i did have a 2.5 catback but now i wanna go three cause of the 2.5 being more restrictive. So i was thinking i was going to do a 3 inch menderal bent exhaust but i was thinking how would a full 3 inch no cat and 2 resonators sound? no muffler either
I'll give you whatever help i can, seeing as people would rather give you **** AFTER you said you've tried searching.
I don't know the answer, but if you haven't already, hit up google and search: cobaltss.net "insert your question/keywords here" the search on this site doesn't work well.
Good luck man.
Good luck man.
Good luck man.
Good luck man.
w/o actual testing, no one can say for sure. Are those ZFR's seeing full potential running the stock catback? Who knows. Unless someone wants to spend the coin to do the tests no one will really know the limit of a 2.5" vs. 3" on these cars.
im keeping my 2.5" dp for now, keep some torque. Got a 3" made today, all the way up near the subframe. little less laggy, better response. a little more aggresive noise too
