Catch can installed
Old 04-27-2007, 10:40 AM
Saltbager's Avatar
Originally Posted by blueta
^^^Not to mention you always feel better after you make something yourself.
Totally true, I makes me feel like i'm worth something lol!
Old 04-27-2007, 10:45 AM
CTCOBALTSSS's Avatar
Originally Posted by Saltbager
I'm in the same boat. I made my own intercooler sprayer for my srt-4 when I had it. It was alot cheaper, nicer looks, and more fun that the CRY o2 kit! I wish i took pictures of it before I sold my car. Because I got nothing but compliments on it!
-$aldi
PM sent about the home made cry02 kit.
Old 04-27-2007, 10:47 AM
Saltbager's Avatar
I never got it .... ?
I just sent it.
Server lag ftl.
Old 05-15-2007, 09:55 AM
I just ordered mine. I'll post pics when it's done.
Old 05-15-2007, 11:04 AM
Rent me! per hour
Area47's Avatar
Originally Posted by kenhebe
Yeah. The catch can is not needed on a normally aspirated car really.
i wouldn't say that.
i had one on my gxp. ls1 variant, crappy gm pcv system. nothing more is needed to be said after this
Old 05-16-2007, 06:49 AM
blueta's Avatar
Got a diagram of the stock pcv system anywhere?
Old 05-16-2007, 07:04 AM
1gmfanatik's Avatar
Any update on the "How To" ????
Old 05-16-2007, 10:32 AM
Red07SSNA's Avatar
PCV "valve" is now an orifice in the center of the intake manifold.
On the 2.2s the orifice is part of the intake and requires a gasket.
On the 2.4 it is a removable plate with gasket as part of the plate.
I haven't seen the 2.0 setup yet.
Old 05-28-2007, 03:47 PM
sscobaltscZ06's Avatar
Im thinking this is the pcv valve setup on my 07 SS/SC where the green arrows point. Even though I have a catch can on the other hose I dont think its right as its not collecting any oil at all which doesnt surprise me as that hose is just a fresh air hose back and forth between valve cover and intake. I think the correct hose to plumb into on the 07 SC model with a catch can is the one with green arrows as I suspect this is the pcv vsystem fitting/hose setup.
Old 05-28-2007, 04:11 PM
  #36
Rent me! per hour
Area47's Avatar
of a gxp? nope. it's a very similar set up to the ls1's
no valley pan evac system, just a pcv in the center of the intake manifold comming off the rear valve cover/head
and a breather comming off the front valve cover/head.
Old 05-28-2007, 04:29 PM
  #37
blueta's Avatar
That tube with the arrows goes to the brake booster
  #38
Fail Less.
Bika's Avatar
sscobaltscZ06, that vac line you are pointing to is not PCV. that is your brake booster vac line. you have the oil/air seperator on the right place. cobalts dont have a "valve" for the positive crank ventilation like the v6's and v8's have.
Old 05-28-2007, 04:32 PM
  #39
blueta's Avatar
O, I see. So instead of having the fresh air tube off the intake tubes you just have a filter (like many do instead) and you are installing the catch in between the pcv valve and vavle cover. I can see how oil can be getting through there since it's coming right off the vavle cover.
Old 05-28-2007, 04:45 PM
  #40
Red07SSNA's Avatar
The hose connects to an opening in the VC -- it is not the PCV valve. The Cobalt does not have a PCV valve like older cars (not one easily removed at least). The "PCV" is a calibrated orifice in the intake manifold. Air is "sucked" in at this orifice at idle and low speeds via the hose at the VC/intake but the flow reverses at higher RPM/WOT and most of the crankcase gases go into the intake. That's when the potential for "sucking" oil occurs.
2.2L engines have a drilled hole in the center of the intake manifold with a removable gasket, while the SS/NA 2.4L has a removable drilled plate and gasket assembly. I'm not sure what the 2.0L SS/SC has as I haven't pulled one off and the factory service manual doesn't show it clearly.
Old 05-28-2007, 05:01 PM
  #41
blueta's Avatar
Sorry for the confusion, I was referring to his GXP.
Old 05-28-2007, 05:11 PM
  #42
Red07SSNA's Avatar
Hope you don't think I was directing that at you. Just using it to clarify the PCV system. A lot of people aren't aware of the PCV system in our engines.
Old 05-28-2007, 05:20 PM
  #43
blueta's Avatar
I did, but all cleared up now.
Old 05-28-2007, 05:32 PM
  #44
Ah...Ok, I havnt had time to go takea look at it, but thanks for clearing it up. I heard the SC's didnt have a pcv system thats why I was checking so im glad thats cleared up.
Just not used to a 4 cyl engine setup at all copared to V8 GM's. Even the 04 LS6 Z06's dont have a pcv valve system either as my 03 LS6 does and catch can install differences and as pointed out some LS1's also. Can get pretty confusing different years/models.
Old 05-28-2007, 09:49 PM
  #45
Red07SSNA's Avatar
Here is the PVC system as pictured in the factory service manual (same picture is in all three engine sections:
https://www.cobaltss.net/gallery/fil.../PCVSystem.jpg
Old 06-08-2007, 07:27 AM
  #46
Well...after 850 miles of in town and freeway medium and hard driving there is absolutley no oil at all in the catch can. Id say probably 200 miles are very hard high rpm in high boost also. So with these results of no oil at all id say the HD catch can doesnt work worth a crap which I figured on that before I even tried it as its not a oil seperator at all OR I have absolutley no blow by at all with this engine at all under boost conditions.
Old 06-08-2007, 08:36 AM
  #47
Well it's cool either way sscobaltscZ06. I have one too and I don't see oil yet. It can't hurt and it's cheap.
Maybe we will end up with some oil after a few thousand miles. I know when I put mine on there was oil in the lines. You too right?
Old 06-08-2007, 09:24 AM
  #48
Red07SSNA's Avatar
That's good news actually! Your catch-can is there just-in-case.
Old 06-08-2007, 09:29 AM
  #49
I didnt notice any in the lines but when I put the CAI on I noticed some oil laying on the bottom edge of the TB. I dontthink it was oil sucked through the intake hose though as it shouldnt puddle there rather be sucked right in the TB,
The HD setup I used 3/8 fittings, but the hose is not 3/8 by a long shot as I thought so I need to change the fittings to at least 7/16 or larger and that will help it. Also putting some wire mesh in the top of the seperator will help also as thats how alot of catch can are setup to further promote good seperation.
RaginChopsuey
10-27-2015 01:27 PM
dennis69
10-20-2015 07:39 AM
justinchinn
10-02-2015 12:18 PM
Delta coupe
09-30-2015 08:11 AM
Bohb
09-27-2015 09:11 PM
Quick Reply: Catch can installed
