clear image 4 to 1 header midlenght + 3" catless dp + stock exhaust
i have a friend who is running that setup right now and it sounds raspy and too loud for his taste. what could we do to make it not as loud and more like stock sound?
anyone have an idea how much a resonator cost that will fit in the stock exhaust?
how much did the 6x30 resonator cost you? where can i get one (links?)
also where did you put it in the exhaust? beginning part after the dp?
mine is a magnaflow, its a 30" body (36 overall) and 6" diameter. look around on summitracing, thats were i bought mine. however if the car is lowered, id recommend against such a large diameter resonator. it hangs a little low and even at that hits the heatsheild in the tunnel, ive scraped it so many times its now rattling quite bad and has to be replaced. largest im considering replacing it with is a 5", although will probly go with a 4".
right next to you. why you wanna race dan?
Im running the clear image header and catless dp with the megan racing pipping and at the end a borla muffler and its sounds great. a bit raspy cuz of the catless at low rpm after that all sweet. i had a megan racing exhaust but muffler took a **** so i put the borla on and im more than happy. try adding a muffler on if not a bigger resonator
fa show. but i don't have one lol
so maybe try to put a cat in the stock exhaust in the beginning or resonator to take away the raspy sound?
camaromanss1992
10-01-2015 10:51 PM
royce777
09-28-2015 07:11 AM
