Clutch recommendations?
So i was set on buying the ott performance stage 2 pulley kit on black friday and right before i ordered it my dealership who is putting in my new engine(warranty due to cracked block between cylinders 2 & 3) called and asked me if id like to put a new clutch in before they put it back together because supposedly it was worn down so bad that it was only going to last a couple days.Now i never realized this because i had never even experienced a single clutch slip or any weird symptoms. I told them to just put the stock clutch back in and that id take care of it so with my ott stage 2 dreams put on hold until Christmas what clutches would you recommend from personal experience that are not pricey that also will go well with my future 2.8 setup?
I completely forgot about the gmpp upgrade clutch thanks for the recommendation i found them on crateenginedepot.com for only 259 so im most likely going to make my order tomorrow on pay day.It should be fine because im not planning on doing any further mods the only thing ill be running is the 2.8 kit,my zzp 3" intake, and a heat exchanger
