cobalt stage 2?
cobalt stage 2?
This is really a dumb question... what exactly is a stage 2 and how can I verify if it is or is not on my car? Please do not flame me.. Is it a different pulley?
thanks
thanks
different pulley different belt, are the most obvious, floor your car mid second and see if the psi gauge goes past 13psi if it does, then you more the likely have a kit on your car or smaller pulley
Do you have bolts on your pulley? Any bolts at all? Stock pulley is pressed on... stage kit is a pressed on hub with a detachable pulley...
Theres a way to tell on the injectors... the oring color.. i think grey is stage 2... you can search that though.
Pulley will give you an idea. GM stage 2 will look like this. See the blue bolts.....
injector color is blue also, well pretty sure anyway. Green is stock color.
satisfied
10-19-2015 12:35 AM
NoBalt123
09-04-2015 07:10 AM
