Compression Test with Interesting Numbers?
add a few drops of oil in then do a compresion test if it gets better then you have a bad ring or a stuck ring
so the bad sticky ring... is it something to be worried about or ?
I bought a oil additive today to see if that will get the piston rings back, if not the motor still pulls hard and theres nothing out of the ordinary.
Last edited by recklessactn; 02-13-2010 at 04:59 PM. Reason: Automerged Doublepost
I wouldn't worry about it one bit. Here's why:
A friend of mine built a 500awhp DSM. Cyl #'s were 140-180-180-180. Car ran AWESOME and still takes a daily beating. Cause of the problem isn't a piston ring.
sounds like someone who "built" a motor by bolting an unnecessarily large turbo on an old worn out engine
Max i'm done in here. If you want to redo it on that 1 cyl with oil let me know we'll figure something out.
