Coolant Temp To Low?
Just like the title says...I drive quite a bit and in michigan right now the temps are 30-50F..and my coolant hardly reaches 130-140..Im wondering if its a stuck open thermostat or something else..cuz during the summer I drive at 180F...just wondering if anyone else is having this issue and if I should be worried. lol
Yeah you will get the code for it soon. Replace the t-stat or just don't worry about it. I have changed them without removing anything else on the car, just need to remove 3 10mm bolts from the housing and pull it out. However, you will have to get creative with some extensions and swivels and such to reach them, and it's kind of awkward. If you pulled the fuse box you would have much better access, i'm just stubborn
z28addiction
09-28-2015 12:03 AM
