cooling Mods
Not really. An aftermarket Heat exchanger does minimal work. GO for a beat run and feel your H/E, it wont even be that hot.
The do a dual pas, the dual pass allows the coolant to stay in the manifold for half the time. Their for the coolant does not heat soak and it keeps transferring the heat instead of becoming hot.
If yo go for a beat run after you install a dual pass you will notice your stock H/E will become hot. The after market H/E compliments the stock H/E when you have dual pass installed.
Somewhere in the words of ss.net past someone said that a after market h/e alone made a big difference. It's a common misconception.
Just so you know. With HP tuners you can turn your pump to 100% all the time such as mine is, You can also make it run when the car is in "ON" and not running to make in intake manifold cold to the touch in about 5 minutes. Try touching your intake manifold after 5 minutes.
I think that pump tuning along with the dual pass was the most effective of my cooling mods.
Not to hijack the thread, but I just did a cobra h/e, and anytime I pull over and put my hand to the cobra h/e, it feels completely cold...like fluid is not even running through it. Normal?
2nd question, hell yea, please give us a how too or pm us with directions. I wanna know!
sounds normal!
Yep:
Intercooler
Intercooler: Indicates if an intercooler pump is fitted to the vehicle.
Intercooler ERT Min: Minimum engine run time to enable intercooler pump.
Intercooler IAT Min: Minimum intake air temperature to enable intercooler pump.
Intercooler
#38
#40
