cooling question
cooling question
Ok so here very very soon for my lsj I'm going to be buying some cooling moods my iat's temps are getting a little to high its hitting dang neer the 190 daily 180 if I'm lucky oh did I forget to mention that I live in Texas where its always hot every day mostly in the high 90 well after these conditions here are my mods I'm doing
duel pass
option b
heat exchanger
replace my ic pump (mine is still working but better replace it now)
aluminum rad
now here is my question is the zzp phenolic intake spacer really help out with cooling have anyone used or using it is it really worth getting
duel pass
option b
heat exchanger
aluminum rad
No its not the dash and I do have a intecepter soo its my ic pump that needs to be changed
edit and plus I'm not that dumb haha I know that the temp of of the coolant I'm not blonde ha I made a funny
Replace your pump first, and see where that gets you before you start throwing other parts at it. Also, the ZZP spacer is no good, it usually leaks.
