Corsa Touring Catback Install/Review
#85
op, you said you had a hissing noise from the catless 3 in. dp? because i have this annoying harmonic ringing noise coming from my exhaust when i accelerate with about 50%-100% throttle above 3500 rpm. it sounds like it could almost be brakes, but im certain that its my exhaust. is that kinda the problem you had?
the stock dp fixed it??
btw i have corsa touring also
#86
...Doh'!
It will still be a while before I can install it. I changed My stock downpipe to a 3 inch flange, and my Long Tube is also a 3" flange. So I'll have to figure out if I just want to change everything over to v-bands all at the same time, or bother trying to change the corsa to a 3" 2-bolt...
#87
I no longer have that downpipe. The hissing was due to an exhaust leak at the 2-bolt flange. I used the crappy gaskets zzp sells for their downpipes.
14129 Corsa Performance - Touring Cat-Back Exhaust System - West Coast Auto Performance
...bought it like a broke a$$ dummy.
Already owe my parents ~$1700 and now i just put ~$780 on my credit card smh...but i love the corsa so much i had to, + its discontinued
