Could use a little help
Rent me! per hour
i have one option left. it's a bit extreme, but with some tweeking here and there it will work fine.
p.s. use your timing, and pe tables. mine will cause issues with your car
Former Cobalt Owner
I dont trust myself messing with those types of tables...still kind of a newbie with the hptuners.
Former Cobalt Owner
Well I put a new Supercharger gasket on and cleaned the TB.....seems to have taken care of the issue. But i will drive it around for a few days just to make sure.
Rent me! per hour
mine surges now. cleanin the maf this weekend. i have found that if you pop the car in neutral and release the clutch. it doesn't do anything stupid and idles down like normal
Although im late, I would clean the MAF also, AKA mass air flow sensor. If you are running an oiled filter oil may be getting on the wires giving false readings to the computer. Its very important to keep it clean, I clean mine every oil change with a oiled air filter.
