cx heat exchanger
cx heat exchanger
ok i have one ordered from ebay on its way and i looked at the how to's and it seems pretty simple. i just want to know if i'm going to need extra hoses or someothing to re route the first h/e to the second h/e...or is the stock set up pretty simple to just re route i'm sure i'll figure it out once i have the bumper off..i just want ot know what i may need to buy...i looked at all the how to's for bioth heat exchanger...and it seems the on;y thing missing is some brackets and a rubber hose am i right or am i missing some stuff
bump>
bump>
It is alot easier to take off the bumper. I did. You have to cut a piece out of your bumper beam to get the filler cap up so that it doesnt hang low and get hit on anything. So I suggest that its better to be safe than sorry. Do it right the first time and take the bumper off!!
Jerren
Jerren
ok another question how much of a difference can i expect to see.any gains ups and down falls... what am i really getting out of this?i know the IAT's will run colder but will i notice a differecne in the way the car runs
I didnt really notice much of a difference wit mine. I haven't had a way to check and see how much cooer my iat temps are either. Then again, the warmest its been here is 19 degrees celcius.
And some basic supplys for ya... 8-10' of hose, 8- 1" hose clamps, and lots of time and patience, getting everyrthing filled back up and getting all the air out of the system.
I used a mixture of distilled water, and dexcool in mine well Cobra but same thing. (about 70% water/ 30% dexcool)
Speaking of Temp drop, on the coolant temp monitor, summer time its in the 180F - 183F range, thats with the stock radiator. What temp reading is any one getting suring summer days or any time ?
It won't change with the bigger Heat Exchanger cause when it gets to a certain degree, you're thermostat opens and cools it until it gets back down. So you're coolant temp will always stay at about the same.
180ish is very normal.
so all in all its pretty simple to just put this thing in there.a couple hoses and some mounting right?that dosen't seem to bad.time consuming but not complicated
THe hoses suck ass.... they use those damn crazy GM clamps, and the things to grab on to are facing up not down....
Make sure you take the time to get all the air out of the system, that is the biggest issue, air in the system means the fluid is flowing properly!
I actually filled my H/E before installing it so it made it less of a hassle to get all the air out!
n20saturn
09-30-2015 12:26 AM
