Dan's Blown Motor
#51
You guys totally fail my test. I wanted to see if you guys knew I was joking, obviously you didn't. You guys need to pay attention better!
Dan, sorry to hear about your motor, but **** happens as I'm sure you know. No sense in being all sad about it, I wasn't when I blew mine up and that was 7 months ago today. Either way it sucks, but its a machine, and machines break. I'm sure Dan will have this thing back together and it will be the badest redline ever.
Once again before you guys start being all bitchy and "flaming" (which flaming only works on people who care, so I'm immune), I was joking. I've always given Dan a hard time about his stuff. Lighten up people
sorry to hear bout the motor man........but just think how much better it ill be once its finished.
#52
#54
Weather you guys believe me or not is not my concern. I made my point (about that I was joking) thats all I can do. If you want to hate my guts forever than so be it, I won't try to stop you.
#56
You do know your a dueche bag and nobody likes you right. I swear your like this kid behind me in my class right now talking about how fast his camry is and how he's gonna put a turbo on it and beat everything. Your an idiot, your car is slow and keep your derogatory comments to yourself. If anyone needs a half assed blower porting we'll pm you otherwise stfu and leave people that are trying new and better things to better the community, like me and dan, the hell alone.
arent you the retard that though his 241 whp on a mustang dyno plus some retarded tuner math ment you had like 340 hp or something retarded like that, and with a 2.7 pulley and 42 lbs. you sir are the idiot.
I agree it was a time thing and would happened either way. But since were giving pros and shout outs. If anyone ever needs a may to make there low numbers seem higher, or a terrible tune, or the advice on how to build an ecotec wrong, or my favorite, how to apparently have a complete beast, yet still run in the 14's at sea level, well be sure to call you!
As for your self professed and i quote. "people that are trying new and better things to better the community, like me and dan, the hell alone" why dont you take your own advice and stfu? no one needed to see you come in the thread and talk smack, your shotty at best reputation proceeds your jags, so just let it be.
#57
LOL your joking right?
It blew up cause the rod bearing failed...that can happen reguardless of its mode of aspiration. It was most likely something we f'ed up when reassembling it.
Rods are forged from factory so there was no real reason to change em out...tho if I do it again ill do aftermarket forged rods just because most likely.
Once again turbo is not the reason for this failure...quit being a s/c fanboi. IIRC your motor is STILL in pieces.
Also my stock internals were fine on both blower AND turbo AND in mint shape when I removed them from the block...I rebuilt the motor cause my timing chain tensioner was never extended from the factory and I was in there anyway so just forge it.
#58
While AJ was defending Dan about blown's comments (that made no indication that he was joking), you attacking AJ for no apparent reason has made you look like the retarded one here. Congrats!
#59
Can the trolls in here please stop posting just because they have keyboards. Thanks
Back on topic...
Last edited by AlphaJaguar5; 10-17-2007 at 03:02 AM. Reason: Automerged Doublepost
#60
could have been a bad install or trash on the rod bearings after the re install of the pistons, or if you didnt put the right bearing back on the right journal it can fail. either way it sucks that it blew!
#61
#62
you didn't hear it from me and I can niether confirm nor deny but expect one more than one and one less than 3 updates VERY soon to both build books.
Last edited by AlphaJaguar5; 10-17-2007 at 03:16 AM. Reason: Automerged Doublepost
#63
too...much...drama...must click the red x on the top right...losing...brain cells.
**** happens. sucks ass, but it does. Sorry your motor blew; i'd be pretty pissed off about it, blocks aren't cheap--I hope you have better luck next time. I hope to see a Dan's New Build thread in the future.
#64
alot of aj's comments were very uncalled for, all i did was meerly flip the coin back onto him. Im not out to start anything, but he argued his credentials, which are lacking.
#65
However if you guys (the majority of the community) don't like me anymore and don't want me around, please vote in my thread. I wouldn't want to be a burden to the community, after all I'm not doing any "new and better things to better the community"... like getting custom rods made thus generating a part number for a new after market rod, or getting custom pistons making part numbers for new aftermarket pistons, or testing out a new clutch, but none of that stuff counts right?
https://www.cobaltss.net/forums/lounge-42/should-i-stay-leave-80728/
#66
Enough retarded high school attention ***** drama.
Next decision Dan needs help with.....return to stock and trade in for something else or built it bigger? Don't let him chicken **** out guys.
#69
Rent me! per hour
if someone has a second car to get them buy. it is time to get big and stupid.
#70
This little fuckup was nothing more than incorrect torque spec on two rod cap bolts. The only Pittsburgh engine rebuild I wasn't around for and the only one with catastrophic failure. Coincidence?
He's gonna kill me for that.
#71
Rent me! per hour
I'm fairly certain this car is capable of bigger numbers. Dan has doubts on engine management but I personally don't think its an issue.
it is capable of large retarded numbers. the quest on the road for supreme lsj hp is always going to be paved with mishaps and destruction of something.
